Help!!!!
Old Jan 18, 2025 | 06:51 PM
saauvenshine's Avatar
saauvenshine
Help!!!!
Is there any visual way to tell a 6 volt voltage regulator from a 12 volt one? Also if converting a 6-to-12-volt system do i need to change horn relay to a 12 volt one. Thanks
Old Jan 18, 2025 | 07:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The voltage is usually stamped or printed on the VR, maybe on the underside.
You don't have to change the horn relay unless you are planning to honk a lot.
tjdad62
Jan 26, 2015 10:40 PM
Sherbo
15
Nov 11, 2010 02:28 PM
Haaser
Apr 10, 2008 05:51 AM
Scott123
Feb 1, 2006 10:10 AM
gl51ford
Jun 28, 2004 07:44 AM
