Overcharging
Old Dec 13, 2006 | 11:04 PM
Haaser's Avatar
Haaser
Cool Overcharging
This seems to be a reoccuing porblem for my truck. Maybe somebody can shed some wisdom but as of right now I don't know. I will be more technical when I have more time to post. But I was fiddling with my horn and it caused a large discharge of the battery and the voltage regulator seems to be stuck open causing a overcharging situation. This has happened to me before and I have fixed the wiring and the grounds. When I change the voltage regulator to a diffrent one I get no charging at all. Two wires are hot while the engine is running on the voltage regulator plugin. The stator and ground are connected properly and the power wire is good.
Old Dec 14, 2006 | 06:04 PM
airharley's Avatar
airharley
Check your horn relay. The relay can ground itself out enough to cause the voltage to increase but not hear the horn.
Old Dec 14, 2006 | 10:46 PM
Haaser's Avatar
Haaser
Would this cause a fairly serious over-charge issue. The horn relay sounds like a good place to check though thanks. Just out of curiosty would a ford 1-G, 2-G, 3-G or 4-G alternator bolt up to the old 302 brackets. Im pretty sure it would and these can be bought as internally regulated alternators too.
Old Dec 14, 2006 | 11:16 PM
airharley's Avatar
airharley
Search google for some article on the swap. I have seen a few but they were mainly geared towards 85 and up mustangs.
Old Dec 15, 2006 | 10:21 AM
daveengelson's Avatar
daveengelson
There is an article in next month's 'classic truck' magazine "all charged up" may find informative. Many of the current articles can be reviewed on their website, will need to wait until next issue, Jan./07, is posted. There is also a Q&A section. In meantime, may want to see if able to locate issue in local news stand and review to determine if any help.
dave
Old Dec 15, 2006 | 11:09 AM
seetwisted's Avatar
seetwisted
Recently went to the ford 3g alternator on my 390,it bolted right in. I understand they were used on mustangs?...It is a one wire style alt. looks good, works good and I found it on eBay from "LOAD BOSS" "ALTERSTART SYSTEMS, Inc." You may even be able to find a 3g at the wreckin' yard.
Old Apr 10, 2008 | 05:51 AM
Cracker289's Avatar
Cracker289
Yeah the junkyard is full of cars that have these:
3G 130amp Donor Vehicles:
(1994-95) Ford Mustang 5.0L
(1994-00) Ford Mustang 3.8L
(1994-97) Ford Thunderbird, Mercury Cougar 3.8L
(1990-95) Ford Taurus, Mercury Sable 3.8L
(1993-99) Ford Taurus, Mercury Sable 3.0L
(1995-98) Ford Windstar 3.8L & 3.0L
(1991-94) Lincoln Continental 3.8L
(1992-97) Ford F Series Pickup
(1992-96) Ford E Series Van
86f250XLT-4x4
Dec 10, 2014 12:56 AM
perryau1996
Aug 28, 2014 09:39 PM
LM32
Mar 10, 2013 11:00 PM
madmader
Feb 26, 2008 05:34 PM
vaman4215
Electrical Systems/Wiring
May 27, 2007 06:31 AM
