DEF heater CEL code? will it put me in limp mode?
Old Jan 18, 2025 | 03:43 PM
gsxr1216's Avatar
gsxr1216
So my truck popped a code last month, "P221C Reductant Heater 'B' Current Too Low" interestingly enough this just happened to occur maybe 15 minutes of run time after i got a low a DEF warning on the screen saying i think i only have 100 miles of DEF left. Anyway i had DEF with me and had planned to fill it up when i got to my destination which is where the light came on. Did some searching and it appears low DEF can cause that code to trip since i guess the heater needs a certain level of DEF to work properly which was news to me. anyway i put a 2.5 gallon jug in it and reset the code and its been fine for 3 weeks or so and yesterday tripped the light again for the same code and it has just under 1/2 tank of DEF in it when it tripped.
So the question, will this put me in limp mode if it gets below 12F which DEF freezes at apparently? I have no idea when i can get it into the dealer for an Appt, or when they would have parts to actually fix it and this week is supposed to be highs in the single digits and negative at night and the truck stays outside. And of course the snowmobile season is finally going to be getting good for me locally and now my truck is acting up... since the 1st time its tripped it hasnt been below 12F so i have had zero performance issues with the truck, just worried I'm going to be hosed with it being so cold coming up...
Old Jan 18, 2025 | 04:21 PM
muisejt's Avatar
muisejt
that's the heater for the line from the tank to the DPF so if that freezes you will definitely be put in limp mode. gonna have to order some new carbides and leave right from your house!
Old Jan 18, 2025 | 05:02 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, heater circuit for the dosing line that goes to the DEF injector.
Not sure if that fault will put it in limp mode or not, but I would imagine if it was it would have already.
If it freezes it will definitely throw some new codes, and then might go to limp mode.
Is your truck beyond the emissions warranty, 5/50 yet?
If not, then get it in to the dealer ASAP.
Old Jan 19, 2025 | 07:31 AM
gsxr1216's Avatar
gsxr1216
Oh, so this isnt the DEF heater in the tank that is messed up? I didnt know the line had a heater also. Truck is under warranty, 2022 with 13k on it, pretty hard to believe that bit the dust with 13k on it..... the issue is getting an Appt and them getting parts so no idea how long it will be till it can actually be fixed, the local dealers dont stock anything for parts, every time i have had to go in the past they always have to order the part.
wondering if i should poke around under there and see if its a loose connection or something then since its not an inside the tank problem apparently.
Old Jan 19, 2025 | 09:31 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, you could take a look, couldn't hurt.
Are there no other larger dealers anywhere you could get the truck in?
Are you in an area, or going to an area, that will get cold enough(below 12*) to freeze the DEF?
Old Jan 19, 2025 | 11:41 AM
Superdave71's Avatar
Superdave71
The connectors for the def tank and heated line are on the bottom of the tank, under a ‘door’ or flap that snaps shut. Pretty easy to get to and check.
Edit: When my def line (tank to exhaust) was bad this was the fault I had :Code: P221C - Reductant Heater 'B' Current Too
LOW
It was an easy repair in the driveway, accessible, not too much time
Old Jan 19, 2025 | 02:01 PM
gsxr1216's Avatar
gsxr1216
LOW
Did you have to replace the entire line in your case from tank to exhaust injector? routing the line looks like a bit of a pain working on the ground under the truck?
thanks!
Old Jan 19, 2025 | 02:06 PM
gsxr1216's Avatar
gsxr1216
yea, -2F is the low for tonight and i want to snowmobile tomorrow and its a 1.5 hour drive, last thing i need is limp mode so the timing of this couldn't be worse.... by friday it should be above 12F for lows so not as much of an issue come then.
theres some other dealers, but same thing nobody stock parts around here, its always diagnose, pick it up and when parts show up make another Apppt, so its a 2 week experience typically to actually get fixed.
Old Jan 20, 2025 | 09:53 AM
Superdave71
thanks!
The whole line needed to be replaced. I put it off for awhile, but it looked worse than it was. Just be sure you have a panel tool for popping off the all the stays.
Old Jan 23, 2025 | 10:58 AM
Dewstain's Avatar
Dewstain
1st Gear
So my 2021 is throwing a code for this heater as well, I haven't scanned it but the app said issue with DEF heater. It's been cold in PA, and I'm definitely smelling like a truck stop lately, so assuming it's just not working.
I'm a '21 CPO with 37K miles, so assuming that's all still under warranty if it straight up broke. I'm pretty astonished at how much complaining this truck did once it hit single digits.
Old Jan 24, 2025 | 09:08 AM
copsey's Avatar
copsey
Did mine last week, took all of 20 minutes. You can verify that the line is the fault by ohm testing it. Should be 3.9ohms on the heating circuit if I remember correctly and mine was over 4kohm. Ordered the line from local dealer, cost $300 with tax, cleared the fault and life is good again.
Old Jan 26, 2025 | 07:32 AM
gsxr1216's Avatar
gsxr1216
Man doesnt seem like they make that heated line very good based on all the people who seem to be having this issue recently.
MYPEARL
Nov 28, 2023 09:56 AM
W7PSK
6.7L Power Stroke Diesel
Dec 22, 2022 11:17 AM
Guess
Dec 29, 2021 02:06 AM
bander boy
Oct 18, 2021 09:51 AM
drivecamo
Jul 9, 2018 04:30 AM
