Got a code on the truck and went to Orielys and they did a print out, but I dont have the code its a P2 something. It says EXAUST fluid level sensor Redacted heater and sender. Is that covered under the customer stisfaction recall I see listed.
Just found out Ford won't cover it. I'm past the warranty period. So, it's on my own dime to fix it.
This truck is costing me a fortune to keep up. New Trans, New EGR, New Fuel Injector Harness, Vaccum pump repair, now this.
Most likely will be my last Ford Truck.
I ran mine for several hundred miles with reductant heater code before I did the R&R of the heater unit, which also has the level sensors.
easy job (I have skid plates too) if you can get it indoors lol. I'm not sure I'd want to do it outside in 20 deg weather though.
Oh Heck no, its in the teens right now. No indoor option at the moment. So, I guess Ill wait until weather improves A LOT.
