2000 Exc LTD Shocks Recommendations Please
Old Jan 19, 2025 | 10:39 AM
Upland_Hunter's Avatar
Upland_Hunter
4wd Low
Originally Posted by Vinny G-the EX man
I thought that w/o a lift you had to use the 4600 series, doesn’t the 5100 series starts with a 2” lift ?
I did find a 5100 series on Amazon that stated 0.0-1.0 lift
Old Jan 19, 2025 | 03:46 PM
mecdac's Avatar
mecdac
Thumbs up
Originally Posted by WE3ZS
While I would agree that a new set of Bilsteins or any other quality shocks will provide an improved ride over worn out shocks, I’m not sure that new shocks will address the OP’s issue of bottoming out more now than in the past……. Maybe it’s just that the bump stops have disintegrated over the past 25 years and now he is feeling the metal on metal impacts vs the bump stops absorbing some of that impact action.
X2 on the bump stops.
Old Jan 19, 2025 | 03:54 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by OldMechanic57
If you have stock original springs you are probably bottoming out the front axle. Pretty common issue with the 4x4 Ex’s.
I agree, if you still have the stock springs you're long overdue to upgrade. I had the stock leafs on my '05 Excursion and quickly found a set of F250 springs for it. It rode so much better and I didn't lift it obnoxiously high, just enough to fit 285s or 315s if I so chose. It towed world better too!
Some new springs and shocks should fix you right up
Old Jan 19, 2025 | 04:06 PM
Upland_Hunter
4wd Low
Thanks so much, Springs did not even come to mind . . .I am printing this all out. Thanks again!
Old Jan 19, 2025 | 07:26 PM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
Shocks: Bilstein 4600s, if stock height. If lifted, a little, Bilstein 5100s. Same shock, just the 5100s are longer.
At 20 plus years, those springs should be tossed. Check out ATS Springs in PA and ask for Junior.
Old Jan 21, 2025 | 09:15 AM
Upland_Hunter
4wd Low
Thanks, I will.
ExcursionPorschePuller
Mar 12, 2021 01:54 AM
dogswife1969
Dec 22, 2015 10:18 AM
yotta1
Nov 24, 2015 06:51 PM
boggerted
Mar 16, 2007 09:24 AM
