Nilight Strip light for tailgate
Old Jan 16, 2025 | 12:45 PM
MarioVF250's Avatar
MarioVF250
4th Gear
Trying to install the NIlight tailgate LED light strip. Brake n turn signals work fine. But when I select reverse It says I have a trailer attacked so I don't have back up sensors. Thoughts?
Old Jan 16, 2025 | 12:50 PM
JoeUser's Avatar
JoeUser
If it's like all the other strip lights that I've seen that mount just below the tailgate, it's powered by the trailer connector. Thus, the truck thinks that you have a trailer attached?
Old Jan 16, 2025 | 12:52 PM
MarioVF250's Avatar
MarioVF250
4th Gear
YES!!! I'm hard wiring into the harness
Old Jan 16, 2025 | 12:56 PM
MarioVF250's Avatar
MarioVF250
4th Gear
Old Jan 16, 2025 | 01:02 PM
JoeUser's Avatar
JoeUser
So, the truck thinks that you have a trailer attached, as I surmised. It's detecting voltage being drawn to power that light strip (thinking that there are trailer lights doing so). I'm not sure that there's any way to overcome this, as it's part of the trailer package programming.
Old Jan 16, 2025 | 01:05 PM
MarioVF250's Avatar
MarioVF250
4th Gear
Ok Thanks. I will look into the wire diagram and see if there is a way around it. Thank you again.
Old Jan 16, 2025 | 01:50 PM
jimzpsd's Avatar
jimzpsd
There should be a two pin connector in front of the license plate area. This provision is for the (3) LED light from Ford, plug and play and it will come on with the headlights.
Old Jan 16, 2025 | 01:55 PM
JoeUser's Avatar
JoeUser
Yeah, but that is just a marker light connection. That light strip the OP is attempting to install is for mirroring the turn, stop, and marker lights.
Old Jan 16, 2025 | 03:18 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Question is, where does the BCM pickup the signal noting something plugged into the trailer plug pulling power?
You would have to hardwire it to the individual lighting circuits to get around that.
I have one that I have never tried to install because I use the trailer plug for trailers.
Old Jan 16, 2025 | 06:12 PM
jimzpsd's Avatar
jimzpsd
You are correct, good catch....thank you
Old Jan 17, 2025 | 07:22 AM
PURSUIT ELECTRONICS's Avatar
PURSUIT ELECTRONICS
F150 LEDs sells a "Y" harness that plugs into the white block on the frame next to the spare tire. This will eliminate the issues with indicating that a trailer is attached. However, when I called, they would only sell it to me, IF, I purchased their extremely overpriced lightbar. But, if you are savvy, you can go down to that plug, locate your wires needed for Left, Right, Marker and Brake, install your weatherproof pigtails and you will be fine then. If I get a chance to get back out to my truck in this cold, I will send you the pictures and pinouts.
Old Jan 17, 2025 | 08:13 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
That would be extremely handy and greatly appreciated.
Old Jan 17, 2025 | 11:01 AM
PURSUIT ELECTRONICS
Here is link for a post for a 2022 Super Duty
https://www.ford-trucks.com/forums/1...pare-tire.html
Old Jan 17, 2025 | 11:02 AM
PURSUIT ELECTRONICS
Without freezing my *** off and going under my truck....here is a link for another post on here
CamoF-250
2021+ F150
Jan 18, 2025 12:30 PM
Bigdawg 2019
Aftermarket Products
May 7, 2021 11:30 AM
Ford Fx4
Oct 29, 2018 07:05 PM
LiquidSteam
Jul 14, 2017 03:36 PM
crewzer
Mar 30, 2017 08:53 AM
