I just added a 37” spare tire in my bed to match my tires on my truck. I added a TPMS to it but when I got the tire mounted the tire shop said I only have 4 spots to monitor my tire pressure via TPMS. Anyone know a way to add a fifth spot so If I have to change a flat tire I will have that tire monitored? He said that the Rams do it so figured ford would be the same but couldn’t figure it out.
You could use the system reset procedure in the owners manual if you are really concerned with the pressure reading with a spare. I don't have one in my spare as I can count on two fingers, the number of times I have had to use a spare in 45 years of driving. If I do need the spare, it’s only on long enough for me to fix or replace the damaged tire.
I mostly want to monitor it so I know if it goes low so I know if I need to air it up. On the ram truck it shows the 5 tires all the time on the TPMS page where our trucks only have the 4. I don’t wanna get a flat and go to put on my spare and it has no air pressure in it. Not a huge deal to manually check it but it would make things a lot easier to see it on the dash.
Some folks mount there spare upside down so it’s easier to check the pressure but it can be a PITA when you let it down and there is no free space for the carrier. I pull my spare every year and check the cable and make sure it has 60 psi in the spare. I also carry a compressor so I can always add air if needed. As you may carry the 37 in the bed, should be rather easy to maintain.
In order to keep track of my spare tire’s pressure I put a TST cap sensor on it. While I don’t always have the system up and running, I periodically put it up to charge it and can see where the pressure is. And of course it’s always up when pulling the rolling house. BTW, the TST 770 display is the BEST!
^^^^^ This is exactly what I do. Another benefit for an old fart like me is kind of remembering where everything is and how to get the damn thing down.
The OP has a 37" tire on, it is too big to fit in the spare location, he is carrying it in the bed.
My question is why in the world would it lose air pressure sitting unused in the bed???
OEM spare sits up under the bed in the frame for years and doesn't lose pressure, why would this spare laying in the bed lose pressure???
The spare tucked up under the bed does lose pressure over time. Temperature changes between the wheel and the tire and the fact that air permeates rubber over time ensures that air will escape from the spare tire. How much may depend on environmental conditions and age but they will all lose pressure. Many folks go to put on a spare only to find out that it’s flat. It wasn’t initially stored that way, they just never checked it because it was never used and the air eventually escaped. I carried a 37 in my bed for a long time and while it was never flat, I did top it off every now and then to make sure it was ready if I needed it.
The spare on our camper loses air pressure over time, to a greater extent than my truck's spare. I carry a Viair air compressor in the truck, along with a bottle jack, a couple of wood blocks, a jump box, a kinetic rope and several soft shackles. Better to be ready than needy.
Well, I had to use the spare on my truck once, had been up under there since new, and was at about 2.5 years in, and while it may not have been aired up to 75 it had enough to use without having to air it up.
But, seems to me that the OP will be spending quite a bit of money and effort to make it so he doesn't have to get his tire gauge out and manually check his spare every few months.
