Spare Tire
Old Apr 26, 2007 | 03:10 PM
B 3000's Avatar
B 3000
Spare Tire
Just pulled the spare tire to check the tire pressure. The spare is a Continental. The tires on the truck are Goodyear.
I'm the 2nd owner bought it with 5000 miles,I know everything is original. I'm suprised to find a different manufacture's tire for a spare.
Old Apr 26, 2007 | 05:30 PM
ranger1999 Bob's Avatar
ranger1999 Bob
they prolly had leftovers from the firestone fiasco
Old Apr 26, 2007 | 07:04 PM
rubydist's Avatar
rubydist
Lots of times they use a different brand/model of tire for the spare compared to the regular tires. They use the cheapest thing they can use for a spare, often not a full-depth tread tire and often not an all-season tire, even if its a 'full size' spare.
Old Apr 26, 2007 | 07:14 PM
michigan66's Avatar
michigan66
Another possibility is that the truck came with Continentials and the purchaser would only buy it if it had Goodyears on it. The swap was made but did not include changing the spare.
Old Apr 26, 2007 | 08:25 PM
RangerPilot's Avatar
RangerPilot
Yep lots of things can cause it. They will go as cheap as possible on the spare since it's only designed to go a hundred miles or so anyways, no reason for them to pay for a full-blown nice tire.
That's why when buying new vehicles, an upgraded spare tire costs more.
Old Apr 26, 2007 | 09:53 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I don't know about that...
My truck came with 5 Goodyear Wranglers, P235/75 R15 XL. The only thing different about the spare was it came mounted and balanced on a steel wheel.
Old Apr 26, 2007 | 11:00 PM
RangerPilot
I dunno, looking at the Ranger on the Ford website, it's $110 for a "full-sized conventional spare tire".
Old Apr 26, 2007 | 11:25 PM
edgl's Avatar
edgl
All my trucks came with all the tires the same size, and brand.
Old Apr 27, 2007 | 08:30 AM
fflintstone's Avatar
fflintstone
It's really an old trick. Dealer or mechanic at dealer gets a bunch of newish but bad tires with bad belt or some sort of flaw for little or nothing from his buddy at a tire shop. As the new vehicles with full size spares come in, he simply swaps the spare with one of the others. Pretty soon he's got a set of brand new tires for himself.
Old Apr 27, 2007 | 01:37 PM
seadoo's Avatar
seadoo
I know when I bought my Splash new in 94 it came with 5 Firestone Firehawk's on it, althought the spare came on a plane steel rim.
Old Apr 27, 2007 | 02:38 PM
B 3000's Avatar
B 3000
On the window sticker reads, "Limited Service Spare Tire".
Maybe this is why Mazda Trucks are cheaper than their cousins.
Old Apr 27, 2007 | 06:54 PM
RangerPilot
When I got new tires last summer I had the best one of the old ones put on the spare rim, the tire that came off was full-size, but it was the original from '94 and definetly needed replacement.
Old Apr 28, 2007 | 08:06 AM
racsan's Avatar
racsan
my tires are 235/75-15's but the spare is a 225/70-15. it looks like a regular tire but has been hot-stamped with "limited use only" on the sidewall. you would think a 4x4 would have the same size spare as the rest of the tires. i know the 235 was the factory size due to the door sticker. i have aluminum wheels and a steel spare. (though ive never seen a factory spare on a alumminum rim) mine had been under the truck for 10 years and never been out. broke the hold-down bolt getting it out. have it mounted in the bed now.
Old Apr 28, 2007 | 04:28 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
It's also possible the original owner didn't want the donut... and rather than fork out the $110 for a full size... just got one a junkyard or something... <shrug>
Old Apr 28, 2007 | 08:20 PM
bkrsmiley's Avatar
bkrsmiley
My 88 RANGER spare !! Still had the tit's on it . But was a limited use tire Used it for 2 weeks !! Side wall cracked and looked like trash but it worked !! Had been there for a while !! 1988 to 2007 they do come in handy whenever you have a flat !! Got me arround !! Found a place used tire's $15.00 each mounted. Got 4 mis matched. Put spare back in to the carrier. Wire and all !! Had to get a jack,and a tire tool !! Hope I do not have to use them for another 19 year's !! SMILEY !!!
