Front License Plate Bracket
Old Jan 14, 2025 | 03:48 PM
ShotgunZ71's Avatar
ShotgunZ71
While I do like the no-drill front license plate bracket, it does have it's limitations. I've found that it doesn't cooperate well with the thicker acrylic plates. The bottom tabs aren't out far enough to get a plate behind them. I cut them off and while it helped get the plate on, now the bottom of the plate pops out some. Hence the reason for those tabs for state plates or regular license plates. Now, I guess the bracket is useless for both. At least it's easy to remove! LOL!
Anyone come up a different solution for thicker vanity plates and such?
Old Jan 14, 2025 | 03:58 PM
MrMBell_11's Avatar
MrMBell_11
Some good info and a link for some ideas in this thread:
https://www.ford-trucks.com/forums/1...e-bracket.html
Good Luck
Old Jan 14, 2025 | 04:04 PM
ShotgunZ71's Avatar
ShotgunZ71
Appreciate that. Nothing worth a poo came up when I did my search. Maybe I didn't have the right wording. You'd think it would have, though, being so recent.
Old Jan 15, 2025 | 06:22 AM
ShotgunZ71's Avatar
ShotgunZ71
Thinking may be able to keep what's there and get some short license plate screws for the bottom holes to keep it flat.
Old Jan 29, 2025 | 05:50 PM
ShotgunZ71's Avatar
ShotgunZ71
Thin plates work pretty good, while the thicker acrylic plates kick out at the bottom, even with the tabs cut off. Thought of adding a couple washers to the screw holes to kick the top of the plate out some.
Ford Fest
2023+ Super Duty
13
Dec 17, 2024 04:02 PM
Lumberman12
Dec 29, 2023 10:23 AM
Groundhog1248
2004 - 2008 F150
Jan 30, 2006 07:43 PM
41Clay
May 20, 2003 10:19 AM
