Are these two computers compatible?
Old Jan 8, 2025 | 07:52 PM
mark lazicky's Avatar
mark lazicky
4wd Low
I've been having issues with my truck and finally came to the point to try another ECM. I've tried a couple that were not appropriate, and just recently found a close one online.
Are these two compatible?
Mine is the first one, out of a 94 f250 5.8 E40D
And the second is out of a 92, same everything.
The middle numbers match!
This one is mine
This one is mine
This is from the 92 i want to purchase
Thanks in advance.
Old Jan 8, 2025 | 11:47 PM
Scndsin's Avatar
Scndsin
No.
12A650 is the Ford engineering identifier for "computer".
It's everything in front of & after that's important.
The second is out of a 95, not a 92
Old Jan 9, 2025 | 06:37 AM
R&RFord's Avatar
R&RFord
As they there 94 and 95 computers, both running SD48B they are probably interchangeable. Hopefully others will chime in with more definite information.
Old Jan 9, 2025 | 06:40 AM
R&RFord's Avatar
R&RFord
I have learned to be very cautious when buying used computers like these. Get detailed photos of the board so you can check for damage before making a decision.
Old Jan 9, 2025 | 08:16 AM
wwhite's Avatar
wwhite
The hardware is exactly the same, same pins on plug, Speed Density, engine size, transmission type, etc.
The only differences is the calibration. Could be air fuel, spark, torque, etc, table differences for sea level and altitude.
I could probably tell you the differences with BAN1. I'd have to little searching for KEG1.
Old Jan 9, 2025 | 08:32 AM
rla2005's Avatar
rla2005
1995 model year PCM has the transmission solenoid protection diodes onboard. The 1994 does not, those diodes are on the transmission solenoid pack. Not an issue to have double diodes, it could to go the other way around.
More info about that 1995 model year PCM (BAN1) here from Subford: https://www.ford-trucks.com/forums/7...l#post20180425
Old Jan 9, 2025 | 11:40 AM
mark lazicky
4wd Low
Originally Posted by Scndsin
No.
Dang ok, do I need to be wary about the KEG1 value as well?
Old Jan 9, 2025 | 12:50 PM
Scndsin's Avatar
Scndsin
As others have said, technically it will work if it is indeed for a 95/5.8/E4OD.
I have no direct knowledge of those facts, so did not & won't recommend purchasing it.
If you had it in hand, I'd say sure. Plug it in & it'll probably work.
Old Jan 9, 2025 | 02:23 PM
wwhite's Avatar
wwhite
What do you mean value?
The BAN1 is a better computer, newer and has diodes in it.
Old Jan 9, 2025 | 03:00 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
That's just the "catch code" used to more quickly identify the calibration. Technically, the calibration code is a different (longer) sequence of numbers, but I usually use the catch code for identification. As others have suggested, you don't absolutely need to match the catch code when replacing a PCM, but you need to know what you're doing if you go that route. Pin locations and operational differences can vary.
Old Jan 9, 2025 | 03:23 PM
wwhite's Avatar
wwhite
I was thinking value $$$ lol, thanks.
Old Jan 9, 2025 | 03:26 PM
wwhite's Avatar
wwhite
Take the cover off the KEG1 and take a picture, and upload it.
I have BAN1 and can compare everything, yes EVERYTHING.
I have the hardware and the software for both calibrations, I will be able to tell you the exact differences in calibrations.
Old Jan 9, 2025 | 04:01 PM
mark lazicky
4wd Low
I just meant the values of the numbers on the computers lol just because they are numbers AND letters.
But yes I think I'm going to go ahead and purchase it and let you guys know.
Do you have to do much to make sure its all good before i put it in? Or should it be plug n play?
Old Jan 10, 2025 | 03:41 PM
wwhite's Avatar
wwhite
Pull the cover off, look at the three capacitors, make sure there not leaking and damaged the board. Many pics online of leaky capacitors on these computers.
NDFD414
Sep 5, 2023 09:10 AM
92obsnewbie
Dec 1, 2019 08:41 PM
Chris Johnson
Projects
Nov 13, 2018 01:49 PM
fordboy_52
Kansas Chapter
May 10, 2007 11:04 PM
