Sponsored by: Real Truck
Headache rack
Old Jan 6, 2025 | 12:42 PM
SuperDutyFord99's Avatar
SuperDutyFord99
2nd Gear
Headache rack
Hey Guys,
need some help with a wiring issue, I just installed a new headache rack on my E99, everything works great except for my back up lights, they dont fully illuminate, I tapped into the truck harness backup light wire thinking that would work and apparently I was wrong, they are LED on the rack, do I need to do something different?
Old Jan 6, 2025 | 05:22 PM
Super Duty DJ's Avatar
Super Duty DJ
It is likely that you don't have a great ground either from the backup lights to the headache rack or from the headache rack to the truck bed. Since you say everything else works well I would look at the ground from the backup lights to the headache rack first.
Old Jan 6, 2025 | 05:35 PM
SuperDutyFord99
2nd Gear
I appreciate the reply and will look at the ground first, the only ground that I know of for the rack is on the frame rail in the wire harness, it’s an aluminum rack
Old Jan 7, 2025 | 06:20 AM
Blue_Oval1's Avatar
Blue_Oval1
Originally Posted by SuperDutyFord99
Hey Guys,
I would first verify there is both +12V and a good ground at the lights, and if there is, swap the positive and ground wires. LEDs are polarized unlike regular lights and won't work if you connect them "backwards."
singlecab250
Aug 31, 2022 10:52 AM
Wertzy
Jul 19, 2017 09:25 AM
Mikey Oldaker
Nov 4, 2012 03:39 PM
bomberboat
Electrical Systems/Wiring
May 4, 2007 05:15 AM
Big Red 5205
Dec 27, 2006 03:40 AM
