Sponsored by: Real Truck
Fuel filter removal tool?
Old Jan 4, 2025 | 11:51 AM
Ralphhead's Avatar
Ralphhead
7th Gear
I'm going to have to crawl under my 2010 4x4 F250 with the 5.4 gasser to change the fuel filter and, needing this to go as smoothly as possible, thought I'd pool the collective wisdom of this forum.
Which brand of filter do you guys recommend? Any particular one(s) to avoid?
What type of removal tool is the best to use (plastic or metal?) (scissor type or collar type, or other?) Any hints on using?
Do I need to release residual pressure in the fuel system (and then prime afterwards) and how best to do this?
​​Any other hints on doing this job? I really hate re-inventing the wheel to do a common job for the first time!
Old Jan 4, 2025 | 12:31 PM
lshort's Avatar
lshort
I always use Napa filters and use the scissor type, just select the size that fits around the fuel line shove it in, I always use some WD40 on the fitting first to make it slide easier.
Here is a good video
Old Jan 4, 2025 | 03:46 PM
SuperDutyScaler's Avatar
SuperDutyScaler
200k on my 5.4 and it only gets motorcraft filters it's entire life since buying it new. Use some rubber safe spray lube before inserting a set of plastic fuel line tools.
do not buy aluminum, they are awful. I have the set linked for nearly twenty years now
https://www.lislecorp.com/specialty-...nnect-tool-set
Old Jan 5, 2025 | 12:54 PM
kurthb's Avatar
kurthb
X2 on Motorcraft filters.
My 2006 doesn't require tools, just push in blue tabs.
SSGG
Apr 3, 2006 05:30 PM
kywildcat103
2004 - 2008 F150
Feb 28, 2006 01:22 PM
makthenif
3.8 & 4.2L V6
Jan 4, 2005 05:46 PM
98explorer
Jul 15, 2004 11:16 PM
yup
Mar 19, 2004 07:52 PM
