fuel filter removal
Old Jul 8, 2001 | 08:36 AM
98explorer's Avatar
98explorer
fuel filter removal
Is there a trick or special tool required to remove the fuel filter off a 98 Ford Explorer? I do not want to resort to a sharp knife. thanks
Old Jul 8, 2001 | 12:23 PM
mefsh's Avatar
mefsh
fuel filter removal
Yes you can buy a special tool for releasing the fuel line, does not cost much. I got mine at O'Reillys and works perfect. I did not want to use a knife of screwdriver either.
Old Jul 8, 2001 | 09:54 PM
jcmac's Avatar
jcmac
fuel filter removal
Old Jun 28, 2004 | 10:11 PM
Msp541's Avatar
Msp541
Get the filter removal tool and it releases very easy, i also use the Motorcraft fuel filter an exact fit and no BS...
Good Luck!
Old Jun 29, 2004 | 12:14 AM
ckrichard's Avatar
ckrichard
Also be sure to depressurize the system before you unhook the fuel lines.
Chris
Old Jun 29, 2004 | 01:44 PM
Msp541's Avatar
Msp541
Good idea (CKRICHARD) theis way the gas line wont have a load of pressure and shoot you in the face when taking the filter off, thanks for the tip!
Old Jun 29, 2004 | 10:10 PM
friech's Avatar
friech
Pull the fuse for the fuel shutoff switch and start the motor. That should depressurize most of the line. Then you can remove the filter with much less spillage. Have a drip pan handy and rags and a spray bottle of water so that after you install the new filter you can spray water on the locations that fuel spilled on. If you are really paranoid, have a fire extinguisher handy as well.
Old Jun 29, 2004 | 10:12 PM
Msp541's Avatar
Msp541
Good Ideas (friech)!!!
Old Jun 30, 2004 | 12:27 PM
hap's Avatar
hap
Wear Goggles
Old Jun 30, 2004 | 12:34 PM
LV Dan's Avatar
LV Dan
Also, there is a valve on the fuel rail on the top of the engine towards the front that allows one to measure the fuel pressure to the injectors. It has a regular Shrader valve like one found on a tire. By using a hose off a bicycle pump, you can attach the hose to the valve and relieve the pressure into a container. Don't just press on the valve or fuel will spray everywhere. And don't forget to put the cap back on because Shrader valves don't always perfectly seal!
One must use the special tool or one will damage the hose connectors. But even with the tool it can be a little tricky getting it to disconnect. To make the release easier, push the fuel line and the filter together while pushing the tool into the fuel line connector. Once the tool seats into the connector, the hose will pull off easily. The tool is not necessary for popping the line back on.
Also, to get the tool over the filter's metal line, I had to cut the opening a little on the flange of the tool. But don't mess with the inserted part as there are lots of little metal fingers that need to be released to disconnect.
Old Jul 15, 2004 | 11:16 PM
Msp541's Avatar
Msp541
Just replaced mine and with depressuring the system its a breeze to replace as long as you have the plastic tool to release the clips.
Good luck to all!
Oldsmoky92
Mar 8, 2012 03:12 PM
98expedition98
Dec 16, 2008 08:58 PM
jzlvr1
1983 - 2012 Ranger & B-Series
Nov 10, 2006 09:18 PM
98_explorer_owner
Feb 14, 2002 08:19 AM
Ron-Bo
1997 - 2003 F150
Feb 17, 2001 04:19 PM
