5.0L Coyote 5.0l Ford OHC Coyote engine for 2011+
2011 Ford 5.0
Old Dec 25, 2024 | 04:29 PM
Rpk3's Avatar
Rpk3
1st Gear
2011 Ford 5.0
Greetings-
IN a bit of an issue with a mechanic whom has swapped my original coyote 5.0 for a salvaged pull from a yard. Does not want to honor anything but I do have photos of the OEM motor including the original dipstick area and tube used to check oil. This guy thought I would not see the swap issue when I now have to check the oil from my driver side valve cover area.
Had the Gaul to charge me for a new Disp stick tube as well. Thankfully a dealer in El Paso had old information from a previous repair of a piston change on the original OEM motor at 119k. They've also verified that this motor since they had it for the piston repair over 7 yrs ago is in fact a DIFFERENT 5.0 motor.
I need help to differentiate the serial numbers on the block to verify for insurance purposes. Anyone have beta on where to find these stamped serials on the blocks?
Thank you.
JJStang
5.0L Coyote
Feb 17, 2019 11:59 PM
Ol Black, 91 F1504x4
Jun 15, 2009 06:18 PM
akaGWall
May 1, 2007 11:55 AM
nascar6dude
Mar 24, 2007 08:12 PM
BrentusBrutus
1978 - 1996 Big Bronco
Jan 20, 2005 07:41 AM
