Sponsored by: Auxito
Misfire code p0308 only in overdrive
Old Dec 24, 2024 | 03:35 PM
Zaquiri's Avatar
Zaquiri
2nd Gear
1997 ford f150 4.6l with a 4r70 transmission fully stock from factory including transmission fluidbut fluid color is still red/pink it has around 75000 miles on it.
So last weekend I took my truck to Kansas about halfway there it got a lot of transmission shudder and it threw the code p0308 which is a misfire code on cylinder 8 replaced coil pack and spark plugs, wires tested fine. Still threw the code after all of that. Then I took it out cleared the codes once again and it didn't throw the code tell I hit about 45-55 mph with alot of transmissions shudder. Cleared the code again this time and took overdrive off and it drove just fine over 3 hrs back to my house never threw the code never had transmission shudder. This is the most confusing fix I've been trying to chase down for the last 5 days. I'm about to do a transmission service on it to try and see if it's worn out/old transmission fluid.
Old Dec 24, 2024 | 05:44 PM
01-7700's Avatar
01-7700
Coil and plug usually corrects the problem. I'd try switching coils between 8 and another to see if you can get the misfire to move. How did you test the wires? I doubt it is caused by the fluid.
Old Dec 24, 2024 | 09:42 PM
lv2race's Avatar
lv2race
A misfire feels like a transmission shudder. I would replace the set of wires before I service the transmission.
Old Dec 25, 2024 | 08:02 AM
manicmechanic007's Avatar
manicmechanic007
His 97 will have plug wires
Old Dec 25, 2024 | 08:06 AM
01-7700's Avatar
01-7700
ok, interesting thanks
Old Dec 25, 2024 | 08:09 AM
manicmechanic007
I'd sure check the plug wires, and inspect the #8 plug (it's a Motorcraft spark plug, correct?)
The plug wires should be roughly 7500 ohms per foot
The coil packs like to fail
Maybe switch those two coil packs as a test (look closely for carbon tracks around the #8 coil terminal first)
Take a photo or use google to make sure and get the wires back on there correctly if swapping coils to test
Old Dec 25, 2024 | 08:20 AM
manicmechanic007
Visited Maine in September this year, beautiful place to say the least, got a lobster roll from Reds. We visited "the end" and the little lighthouse up the road, also Bar Harbor. Marvelous, just marvelous
Old Dec 25, 2024 | 08:37 AM
01-7700's Avatar
01-7700
We love it here ! Maine has so much beauty.
The locals hate Red's because it's too successful and causes traffic problems LOL. Best place to go, imho.
Old Dec 29, 2024 | 03:09 PM
Zaquiri's Avatar
Zaquiri
2nd Gear
So sorry I've been Hella busy with work but I check the wires by swapping 7 and 8 plug wires and the code stayed on 8 so now I'm about to swap 7 and 8 injector to see if that's the problem. BTW checked for vacuum leaks around the intake and there wasn't any from my checks but if you guys have any other test or suggestions let me know thank you all for at least leading me away from the transmission
Old Dec 29, 2024 | 04:58 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Just pull the plug and “read” it.
ETA: I guess you didn’t do that with the last set. I guess you can swap injectors, but a compression test should go in as well. If that truck has 75,000 miles on it, cool. But, 27-year old engines need love, too.
nickshu
Jan 19, 2024 07:26 AM
friskyjake
Jul 20, 2012 09:32 PM
NJ_98Navigator
Jul 26, 2011 06:01 PM
pkenn7
Modular V10 (6.8l)
Jan 6, 2010 07:29 PM
