Emissions versus Transmissions
Old Dec 19, 2024 | 04:14 PM
oldF150XLT's Avatar
oldF150XLT
Trailering
Question Emissions versus Transmissions
I'm rebuilding a 1987 F150 XLT Lariat 2WD that had a trashed engine (351W). I wanted to buy a replacement C6 transmission but the place said that what they sell won't meet emissions standards, thus couldn't be used on my truck if I was going to drive it on the street?
I never heard of anything like that before. I live in Missouri, for what that's worth.
So, what on the transmission affects emissions standards?
Old Dec 19, 2024 | 04:41 PM
OBS460's Avatar
OBS460
Depending on your budget you could just look at something from somewhere like Summit/Jegs like a TCI unit. I would source the parts myself and rebuild a bulletproof unit with a full manual valve body. A C6 can't be that hard to rebuild.
Old Dec 19, 2024 | 04:53 PM
oldF150XLT's Avatar
oldF150XLT
Trailering
Thanks for the info. I don't really have a good shop to work in and have never torn an automatic transmission apart, so am a bit uneasy about diving into something that I plan to use for a daily driver.
TCI is the place that told me their transmission which is advertised as stock and suitable for RV use would not be street legal because it was not emissions compliant.
The stuff that I've seen at Summit & Jegs is about a thousand dollars more.
Certified Transmission told me that they only do install/replace and won't sell one off the shelf. I can't do that because the truck is not drivable, has no engine at this point.
I do appreciate your suggestions.
Old Dec 19, 2024 | 05:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Two things.
First, the truck was certified for emissions with a transmission that wasn't a C6. Changing almost anything in the drivetrain changes that configuration to one that was not certified as compliant.
Second, the C6 will result in much higher engine RPM, which burns more fuel, which causes more emissions.
Old Dec 19, 2024 | 06:16 PM
tjc transport's Avatar
tjc transport
i ain't rite
did your truck come originally with a C6, or was there another type trans in it.
Old Dec 19, 2024 | 07:46 PM
Conanski's Avatar
Conanski
In '87 pretty much the ONLY auto trans available behind the 351w was a C6, the E4OD didn't exit yet and in general Ford didn't put an AOD behind that motor in a truck.
Was this a high performance shop specializing in racing applications? A trans with a high stall converter would have some small effect on emissions but so what, how many people are running around with gutted cats or wide open exhausts? How many diesel trucks you see rollin coal? How many heavily modified hot rods you see cruising the streets?
My response here would have been... well that's cute but it's none of your business, you going to sell me a transmission or do I go somewhere else?
Old Dec 19, 2024 | 08:05 PM
C6Scott's Avatar
C6Scott
I’ve never heard of such a thing before either. I think they are mistaken. if it were my truck and I didn’t want to attempt it myself I’d find a local shop to rebuild it and install it yourself. You’d save a lot of money. If it’s going to be a stock or close to stock truck you don’t need a fancy TCI unit. The C6 is pretty durable in its stock configuration IMO.
Old Dec 20, 2024 | 08:10 AM
manicmechanic007's Avatar
manicmechanic007
1987 351 probably had a C6
So, dime a dozen, get another, or get yours rebuilt, preferably both
I'd throw a used one in it for now
Then have your original one rebuilt
Also, it's quite easy to overhaul one, but finding hard parts might be tough if you are not in the industry
Look to pay 300-500 bucks for a good used one or 1500 for a good reman with a new torque converter
Have fun
Another note, Ford did put a AOD trans in a F150 behind the 5.0 et al.
So find out what trans you have first
Old Dec 20, 2024 | 08:37 AM
Hit Man X's Avatar
Hit Man X
IMO, build a decent AOD starting with a '92 or '93 core as they are the last units. Gain economy with the 33% OD, it is plenty strong once hopped up a bit and kept out of OD until needed (freeway cruising).
Call Transtar if you need parts, but you better know what you are doing and ordering.
Old Dec 20, 2024 | 09:25 AM
My4Fordtrucks's Avatar
My4Fordtrucks
It definitely had a C6 behind the 351. So the original engine was swapped from a 5.0L to a 5.8L at some point because the OP said …
I have never heard of a transmission affecting emissions especially since your truck already has that model trans. What C6 transmission were you trying to buy that they wouldn’t sell/install in your truck? You could go back and show them the trans code from door sticker that says the truck came with a C6 but I wouldn’t want give them any money. I’d be looking for another shop.
Old Dec 20, 2024 | 09:28 AM
1Butcher's Avatar
1Butcher
Why would you want to deal with a shop that does not seem to know what they are talking about? Why would you push them into that job?
I would evaluate what you are doing and see what other options you got.
Old Dec 20, 2024 | 09:34 AM
My4Fordtrucks
^^^ It could be an excuse because they do not want to work on an old vehicle.
Old Dec 20, 2024 | 10:11 AM
manicmechanic007
Trans R&R is one of the easiest heavy line jobs out there
Pull it out yourself and take it to get overhauled?
Old Dec 20, 2024 | 10:13 AM
manicmechanic007
The only thing that affects the emissions is the rpm of the engine at freeway speed. CAFE is down with the C6 vs the AOD
it was, and still is, all about corporate average fuel economy (CAFE) To THEM = OBEY
Old Dec 20, 2024 | 10:39 AM
My4Fordtrucks
Which is irrelevant since the truck came from the factory with a C6. If the owner wants to install an upgraded transmission with different internal parts that has nothing to do CAFE standards. The truck is 37 years old.
