2003 Excursion 4r100 trans flush
Old Dec 18, 2024 | 01:59 PM
99ManualFlatbedFarmTruck's Avatar
My parents have a 2003 Ford Excursion with 194,000 miles and have owned it since 166,000 miles and never has had the 4r100 trans serviced. I was told on auto transmissions that were old or you never knew their last service to never flush them with a flushing machine and to just change the ATF and clean the pan and replace the filter, is flushing this transmission going to hurt it? or is it better to just change atf and filter and clean pan? Also how much ATF do I need for a transmission service and it takes motorcraft LV correct? Thanks
Old Dec 18, 2024 | 03:22 PM
John in OkieLand's Avatar
John in OkieLand
personally,
I would avoid a machine that puts pressure on the transmission.
just get some clear hose about 15 feet long, a nipple to go into the output port on the transmission, and start the engine, watch the fluid as it goes into a bucket, when it bubbles, or quits, kill the engine, refill the transmission,
repeat until you have poured in more ATF than it can hold...
that will flush the TQ normally.
Old Dec 18, 2024 | 08:09 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Here is how to do it: https://www.ford-trucks.com/articles...-transmission/
Use MERCON V. MERCON LV will destroy a 4R100 in a very short time.
Old Dec 19, 2024 | 05:28 AM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
Mark, as a side question for the 5R110W transmission in the 6.0 Excursions (not the 4R100 found in the rest of them)...there are still some sources of the original MERCON SP available. Is it better to use LV or SP for the 5R110W? I have found conflicting information.
Thank you.
Old Dec 19, 2024 | 05:09 PM
Mark Kovalsky
I don't know if you can still get MERCON SP anywhere. I don't have a 5R110W so I haven't looked. I'd prefer that over MERCON LV, but LV will work.
Old Dec 20, 2024 | 03:39 PM
DavenTn's Avatar
DavenTn
Amazon Amazon
Old Jan 3, 2025 | 08:06 AM
Excurvelle's Avatar
Excurvelle
I have 283K on my 4R100 and I have no idea if the fluid has been changed, it is dark but not burnt. I have been thinking about servicing it even to the point of dropping the old fluid into a bucket, removing the pan and looking inside, changing the filter but IDK if new fluid would be advisable or reuse the old fluid? Lots of stories about fluid changes on high mileage transmissions.
Thoughts?
Old Jan 3, 2025 | 09:20 AM
WE3ZS's Avatar
WE3ZS
Thoughts?
Your 6.0 doesn’t have the 4 speed 4R100, you have the 5 speed 5R-something-something………. That’s the limit of my tech abilities this morning.
Old Jan 3, 2025 | 09:38 AM
Mark Kovalsky
There are a lot of stories of transmissions failing right after a fluid change. Here is why, in my opinion.
Many people ignore the transmission maintenance. Once it has a lot of miles, say maybe 283K, something starts to go wrong. Now they change the fluid, hoping that's what's wrong. But the problem isn't that the fluid needs to be changed, the problem is that the trans has been ignored and the old, worn out fluid allowed the trans to fail. Now they put new fluid in it and the trans completes the failure that started before the fluid change. If they hadn't changed the fluid it probably would have failed a few miles sooner.
If the trans is in good shape new fluid can only help it. If the trans has already begun to fail new fluid isn't going to magically fix it.
Old Jan 3, 2025 | 10:10 AM
John in OkieLand
@Mark Kovalsky,
what is your opinion on leaving the current filter alone, just changing the fluid?
Valvoline Quick Change stations no longer drop the plug, they stuff a hose down the filler tube, and siphon the fluid out, and refill it.
Old Jan 3, 2025 | 10:13 AM
unleashd's Avatar
unleashd
Tom, you forgot that @Excurvelle got himself a v10 recently. You need a second coffee
Old Jan 3, 2025 | 02:40 PM
WE3ZS's Avatar
WE3ZS
Yep, more coffee is needed! Totally forgot the new V-10. I should have know better that he would have better maint on his tow rig 6.0.
Old Jan 3, 2025 | 03:57 PM
Mark Kovalsky
If the filter has enough junk in it to cause a problem the transmission has already failed. Until the filters changed in 2008 the filter would last the life of the trans.
That will change less than half of the fluid. I consider that one step up from throwing money away.
Old Jan 3, 2025 | 04:31 PM
John in OkieLand
Thank you,
I will do it myself, with the hose and 5 gallon bucket.
Old Jan 3, 2025 | 06:05 PM
Excurvelle's Avatar
Excurvelle
Yeah, my baby is jealous I am working on the v-10. I keep the 6.0L over maintained.
Qwazert
6.2L V8
Dec 4, 2019 12:33 PM
SoCalAngler
Modular V10 (6.8l)
Oct 17, 2016 08:17 AM
BCfordman38
Aug 19, 2016 04:19 PM
emspjay
Dec 10, 2014 06:14 AM
TXBob
Jun 5, 2010 12:11 PM
