While passing thru Lynden yesterday, I stopped in at O'Reilly's and picked up 4 qts of Mercon LV (for an early Spring trans service). The stuff is a bit pricey ($8 USD/qt) but I will be using only OEM fluid in the trans!
So, if I drop the pan and change out the internal transmission filter...how many qts am I going to need?
Has anyone installed an exterior filter on one of these?
Mine took 10 quarts of Mercon LV. Dropped pan and changed filter also.
I got 11 quarts out of mine with a filter change on a hot transmission, I bought my Motocraft LV off Amazon for a lot cheaper price than $8 a quart, I bought a case of 12.
