blinker problems
Old Dec 17, 2024 | 07:57 PM
buddyrow's Avatar
buddyrow
blinker problems
Hey guys I need some help figuring out what is going on with my blinkers on my 1973 f100.
I am in the process of putting truck back together from paint and body work . Before I put cluster back in I started checking out my lights
Everything works except my blinkers, The light will come on left and right but will not blink .The flashers work good, I just put new blinker component on but still does not blink
I would appreciate if someone can help me 4
Thanks again
Old Dec 17, 2024 | 08:10 PM
mterickson's Avatar
mterickson
Thanks again
By blinker component do you mean the little canister flasher? There should be two of them. One for t/s and the other for the hazards. A quick test would be to swap them and see if t/s start working and the hazards stay on solid.
Is this what you replaced?
Old Dec 17, 2024 | 08:12 PM
mterickson's Avatar
mterickson
Are you still using regular bulbs or did you get LED replacements?
Old Dec 17, 2024 | 09:38 PM
Rubiranch's Avatar
Rubiranch
You might just be low on blinker fluid.
Sorry. I just had to.
Old Dec 18, 2024 | 07:06 AM
buddyrow's Avatar
buddyrow
blinker
Thanks for feedback
I did replace the one you suggested Would a bad ground cause this problem?
Thanks
Old Dec 18, 2024 | 07:59 AM
mterickson's Avatar
mterickson
Yes, bad grounds can cause all sorts of problems. It could be the t/s switch too.
When you activate the t/s does the t/s light get brighter and stay on solid or do you see no change at the bulb when you activate the t/s?
Old Dec 18, 2024 | 07:03 PM
buddyrow's Avatar
buddyrow
problem solved
Worked on blinkers again today. I found that I had bad ground at tail light assembly.
Thanks for all the feed back
Everett stormy
Dec 12, 2023 09:01 PM
f1butcher
Jun 21, 2022 01:54 PM
80ford100
16
Nov 16, 2014 05:01 PM
hannahbarie
13
Jun 2, 2010 02:27 PM
73f100shorty
Electrical Systems/Wiring
Jun 7, 2007 07:24 AM
