Sponsored by: Real Truck
U0100:00-8B - Missing Communication With ECM(Engine Control Module)/PCM (Powertrain Control Module)
Old Dec 17, 2024 | 08:33 AM
1Kurgan1's Avatar
1Kurgan1
4wd Low
2013 F-250 6.2L Gasser
Code Thrown:
  • U0100:00-8B - Missing Communication With ECM(Engine Control Module)/PCM (Powertrain Control Module) A
Issues:
  • No crank, no start
  • Only white gear lights, no orange selected gear
  • Service Advancetrack
  • Temp icon on dash
Things I have tried:
  • Checking firewall connections by battery
  • Checking firewall grounds by battery
  • Wiggling connector attached to e-brake bracket
Thoughts:
  • Going to physically disconnect harness from e-brake assembly, pull it apart and connect it again. Then zip-tie it up to something else
Story:
I drove it a week or two ago without an issue. Snow is in the forecast so I got the plow mounts on the other night and was going to get the plow on, but the truck would not start. When the key is turned to accessory I noticed it does not indicated the gear with an orange light (they all light up white, just no indicated gear is selected). It can shift through them all and it does physically enter them (or at least I can tell it hits neutral). But when I hit the key it just clicks, and not from the starter, just from the passenger side dash area. Also the door switches (locks, windows, etc) go out while I hit the key temporarily). It pops up with a temp warning icon on the dash and also says to "Service Advancetrack". I scanned it and the only code that comes back is this one I checked the passenger side firewall connections under the hood and they all seem good. The grounds under those are connected. I checked the connector under the driver side dash by the e-brake and pushed on it, wiggled it, and that seemed fine.
Any ideas? I just drove this not long ago without a problem, all of a sudden it just refuses to even try and start?
Old Dec 17, 2024 | 11:27 PM
1Kurgan1's Avatar
1Kurgan1
4wd Low
Unfortunately I pulled that hardness/connector attached to the e-brake assembly. Separated the connector completely and inspected it, everything appeared normal. Then I put it back together, but it had no effect. Which is a bit disheartening because all of the threads I come across for this has almost everyone saying that fixed their problems.
Old Dec 19, 2024 | 10:52 PM
1Kurgan1's Avatar
1Kurgan1
4wd Low
Well after digging I found the source of the problem. I found another thread talking about the under hood relay having broken wires that cause the same symptoms as the e-brake harness. So I popped that relay out and found out that one of the female sides snapped off and is pushed down into the box.
So now is figuring out how the hell I can fix this (because replacing the entire fuse box is definitely not happening). I don't know if it is possible to even get that thing back up in place, that is an internal post that has no external wire to bypass.
Any ideas on the best way to go about this, or has anyone done this before?
cbenn
6.7L Power Stroke Diesel
Jun 5, 2024 06:10 AM
Robo02
Jun 3, 2024 04:57 PM
JRBurn
Aug 3, 2023 09:49 AM
fordboy2
Jan 6, 2022 04:45 PM
cornutsoffroad
Nov 1, 2008 01:34 PM
