Lighting Control Module
Old Jun 4, 2024 | 09:46 PM
cbenn's Avatar
cbenn
4wd Low
I may need to replace the Lighting Control Module in my 17/350, I do know the location is above the gas pedal but see no way to get it out from under the dash so is it easier pulling dash cluster and reaching it from there? Any input would be much appreciated
Old Jun 5, 2024 | 05:04 AM
bewildered 7.3's Avatar
bewildered 7.3
Are you referring to the tow module? I replaced mine without any disassembly. I would have to look under the dash again to remember what I did but it was pretty easy.
Old Jun 5, 2024 | 06:10 AM
cbenn's Avatar
cbenn
4wd Low
That module is on left side by emergency brake and you can reach that one, the LCM looks similar LCM is above the gas pedal just under where the gauge cluster is, thank you for the reply.
JRBurn
Aug 3, 2023 09:49 AM
fordboy2
6.7L Power Stroke Diesel
Jan 6, 2022 04:45 PM
idyll1
Aug 6, 2003 10:50 PM
drof78150
Jan 15, 2002 07:12 PM
