Powertrain Control Module
Old Jun 3, 2024 | 10:59 AM
Robo02's Avatar
Robo02
Trailering
Received a message from service department, stated powertrain control module needs to be recalibrated for emissions, why am I leery of this, I live in Florida and we don't test emissions, thanks
Old Jun 3, 2024 | 01:09 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Since it is emissions, they will bug you about it until it gets done, it is federal, not state, feds bug Ford, Ford bugs you.
And, there is no performance reason to not get it done, just the time it takes you to take it in.
Old Jun 3, 2024 | 01:25 PM
Dozzer's Avatar
Dozzer
Lol they are from the Government and here to help
Old Jun 3, 2024 | 01:41 PM
OBS460's Avatar
OBS460
Might want to wait for someone who had it done already chime in and hear about the before and after differences. If it guzzles more DEF after the update you might want to keep putting it off as long as possible. This is almost certainly reacted to the Cummins settlement for cheating emissions. Ford might be trying to cover their ***.
Old Jun 3, 2024 | 02:36 PM
Montesa's Avatar
Montesa
The newer Cummins uses considerably more DEF but less EGR. Seems like a win to me.
Old Jun 3, 2024 | 03:06 PM
OBS460's Avatar
OBS460
Is it a win if your DEF injector is being used more frequently which could result in more frequent service/replacement? Is the EGR a problem on the newest 6.7s?
Old Jun 3, 2024 | 03:21 PM
Montesa's Avatar
Montesa
Not a problem that I know of but the oil stays somewhat cleaner and there's less carbon build up. You had to replace the EGR filter at 68k miles on the pre '19 trucks but that requirement is now gone.
Old Jun 3, 2024 | 04:57 PM
speakerfritz's Avatar
speakerfritz
so do you have a 2017 thru 2019 6.7?
theres a service bulliten that require a reprogram becuase the existing program does not do NOX alerts very well. so if your NOX sensors are reading high NOX, you could get bad news.
JRBurn
Aug 3, 2023 09:49 AM
PoorUserName
Electrical Systems/Wiring
Nov 1, 2020 06:30 AM
PoorUserName
Nov 1, 2020 04:35 AM
marine57_4
6.7L Power Stroke Diesel
Jun 20, 2015 04:25 PM
