Heater issue
Old Dec 16, 2024 | 11:16 AM
SDON's Avatar
SDON
2nd Gear
Heater issue
I have read some post about heater cores. I got my hoses off and flushed thru the return and supply side of the heater core. No issues and I didnt get any scale out. For some reason I cant get heat in the truck. I put a new blend door actuator in and a new vaccum motor. Anything else I should check?
Old Dec 16, 2024 | 12:42 PM
TooManyToys.'s Avatar
TooManyToys.
Do you have a vacuum-controlled flow valve in your truck? Some do, some don't.
If the grey vacuum line comes off, the flow can be shut off. Sometimes, the lever to open/close the valve breaks.
Old Dec 16, 2024 | 12:45 PM
SDON's Avatar
SDON
2nd Gear
Yes I do. I pulled the hose off then put it back on. I watched the valve open too. While part of the hose was off, I ran the truck till the valve opend and saw flow. Maybe a air flow door is stuck? Im draining the whole aystem and putting in new fluid this week.
96f150
1997 - 2003 F150
Mar 30, 2020 08:49 PM
cardana24
1997 - 2003 F150
18
Mar 9, 2018 05:38 PM
17fordguy
Oct 11, 2009 10:17 AM
pikiluvi
Apr 18, 2005 02:49 PM
blue ranger
1983 - 2012 Ranger & B-Series
Jan 30, 2005 11:31 PM
