I’ve got a 90 f150 trying to chase down a no start spark issue. I’ve replaced icm, coil, ignition switch, computer and distributor. I believe it all mostly boiled down to a bad ignition switch. I have power to coil, spark from coil. Rotor is turning, I also have very weak spark from distributor to plug wires. Almost intermittent spark. I have a lot of time and money tied in this truck, would love to get this thing in the road. Thanks for the help.
You're gunna need a volt meter to figure this one out. How many volts is the ignition coil getting while you're cranking the engine? If you use a test light on the negative side of the coil, does it flash consistently while you're cranking?
It's looks like it should be enough to get her started.
Are you 100% sure you have the distributer installed correctly? Alot of the time, the owner installed the distributer to fire at Top Dead Center on the EXHAUST stroke, instead of the COMPRESSION stroke.
No I can’t say for sure. This has been on my mind heavy, all the other parts I changed myself but was a little intimidated with getting the timing correct when swapping the distributor so I hired a “ford” guy. At that point I was just firing the parts cannon for the spark issue, and the distributor didn’t fix it. Fast forward till now, replaced the ignition switch and I have spark but no start.
I’ve read and watched so many videos and articles on the subject I’m sure I could handle it but just wanna make sure I’m understanding things right.
1)unplug spout connnector
2)remove #1 plug
3)turn engine over by hand until air pushes from plug hole
4) continue to turn engine by hand until tdc mark on balancer
5)point rotor toward #1 and install distributor
does this seem basically correct ?
I live in a small town and I’m at the point now where having a garage do it is out of the question, and I’m pretty limited as far as having anyone locally assist me hands on so it’s just me and what I can find on the forums.
1)unplug spout connnector (this has nothing to do with clocking the distributer correctly)
2)remove #1 plug
3)turn engine over (clockwise, when looking from the front) by hand until air pushes from plug hole
4) continue to turn engine (clockwise) by hand until tdc mark on balancer
Repeat steps 2-4 with the distributer installed as it is. When you got it lined up on TDC on the compression stroke, remove the distributer cap and see which sparkplug wire terminal it's pointing to. It should be pointing at #1.
You can also stick a wooden dowel or a plastic stick in the #1 sparkplug hole and make sure the piston is really at TDC. Sometimes, timing marks get screwed up or changed, and they're no longer accurate.
[s]1)unplug spout connnector (this has nothing to do with clocking the distributer correctly)
2)remove #1 plug
Thanks a lot for the great help, by doing this if my rotor is NOT pointed at #1 then I can conclude the distributor was installed incorrectly and on the exhaust stroke, right?
Well, you can conclude that's it's not installed correctly. It may be pointing at any of the other 7 cylinders. If it is, the engine won't run.
okay so after double checking and confirming, getting on the compression stroke, then bumping it on over to 0 degrees tdc, it looks like the rotor is pointed towards right around #5. Whats my next move? Thanks again!!
