TPMS compatibility from previous generations
Old Dec 12, 2024 | 11:49 AM
sam14au's Avatar
sam14au
4wd High
I'm looking to get a set of used OEM take-off wheels for use on our 2020 F350 XLT (7.3 gasser if that matters).
1) From what I've read about hub bore size, any prior OEM wheels from '99 onward should work (ie trucks with Dana axles can't take Sterling axle wheels, but Sterling axles can use both)
2) For TPMS compatibility, I'm assuming that anything in the '17-'22 range will work, but I'm wondering if previous generations ('11-16, '08-10') work? It looks like they are all 315Mhz from initial implementation in '07 until the change to 433Mhz in 2024, but the part numbers are different for different model years...
Old Dec 12, 2024 | 01:01 PM
acdii's Avatar
acdii
Start with 2017. The 16 and older may not work. There was a conversion period between steel body and aluminum, which didn't happen until the 2017 MY. You should be OK with TPMS starting 2017.
Old Dec 12, 2024 | 03:39 PM
sam14au's Avatar
sam14au
4wd High
There is a set of 2015s available near me, so I was really hoping they would work - but this sounds like they might or might not...
Old Dec 12, 2024 | 04:09 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Put new sensors in them, they don't cost that much.
Old Dec 12, 2024 | 05:20 PM
T. Banning's Avatar
T. Banning
As far as your axle goes, it should be a Sterling axle seeing as it’s a 7.3 gas.
Old Dec 13, 2024 | 08:04 AM
acdii's Avatar
acdii
They would work on an F150, but I don't think ford updated the Superduty receivers until it went to the aluminum body in 2017. You can get sensors on Amazon for ~$10 each or less. Don't waste time or money on used ones, think about it, they use a battery that can't be replaced, so a sensor from 2015 will be at the end of its lifespan by now, they are only good for roughly 10 years.
4x4boss
Mar 24, 2020 07:15 PM
kylant
Jan 26, 2019 09:21 PM
SixtyPilot
Oct 26, 2018 07:13 AM
94_7.3_IDI
Mar 28, 2013 06:16 PM
zukinut
Jan 29, 2013 02:16 PM
