Steering wheel controls - easily removeable?
Old Dec 10, 2024 | 02:57 PM
JoeUser's Avatar
JoeUser
I just got through watching A-Rod's excellent video about installing a heated steering wheel, to get some pointers.
What I'm trying to determine is how easy it is to just loosen the steering wheel controls on my '20 XLT, just enough so that I can run a leather steering wheel wrap underneath the controls at the spokes (for a clean install, so as to not overlap the control surfaces with leather).
Is it possible to just lift the edge of the controls near the wheel spokes without having to disassemble the wheel components (air bag then controls)? I just don't want to try prying plastic only to have it bust unexpectedly, that'd be very bad...
Old Dec 11, 2024 | 11:52 AM
JoeUser's Avatar
JoeUser
Just for grins, I opened my case of plastic body spunges and such, and I was able to gently lift the edge of the left-most bezel at the spoke position and where the buttons are located. I didn't go very far beyond that point as I didn't want to break the plastic (no idea just where and how that bezel is attached).
So, I might be able to push the leather underneath that bezel for a snug fit (and use some 3M double-sided tape to secure it). It would be nice to know just where that bezel attaches to the steering wheel and how, as I haven't been able to find a clear photo of a steering wheel minus the airbag (and paused videos aren't too helpful thus far).
I guess I'll eventually be reduced to removing the airbag to get the answer as to how that bezel attaches to the steering wheel, and if it's easily removed and reinstalled. Either that, or take the risk and try wedging the leather under the edges of the button bezels (and hope I don't bust the plastic)...
Old Dec 11, 2024 | 12:24 PM
Neohio's Avatar
Neohio
www.DieselCurrent.com
Check out some of the 21+ F150 raptor steering wheel swaps on youtube. It might give you a better idea of how the wheel is assembled.
Old Dec 11, 2024 | 12:36 PM
JoeUser's Avatar
JoeUser
Ah, thanks. I never factored Raptor wheel swaps into my thoughts. I'll take a cruise through the 'tube this evening.
Old Dec 11, 2024 | 12:43 PM
Neohio's Avatar
Neohio
I have come across other videos of guys installing Amazon carbon fiber wheels. They showed swapping buttons. I just don't recall enough of the details to be a help.
Old Dec 11, 2024 | 12:52 PM
JoeUser's Avatar
JoeUser
I was initially attempting to locate a leather wrapped take off steering wheel (say, from a Lariat or KR), but they're rarer than hen's teeth. And those that do have them want a fortune for them. So, decided to try wrapping my existing wheel, instead.
I never considered shopping for another wheel on fleaBay, but might see what's available in that venue. Never know, might just find a used OEM wheel.
Old Dec 11, 2024 | 01:05 PM
Neohio's Avatar
Neohio
I remember the Arod video, maybe reach out to him and see what his customer did with the takeoff wheel?
I believe your 20 has the same wheel as a 15-20 F150. Should be plenty of wheels out there.
car-parts.com should have some local to you.
Old Dec 13, 2024 | 07:37 AM
B-ManFX4's Avatar
B-ManFX4
When I added ACC to my 2015 F-150, I had to swap out the steering wheel controls. Disassembly of the steering wheel is straight forward and is very easy. People get too excited about the airbag - it is not a big deal. You cannot trigger the bag by connecting or disconnecting the wiring harness. In your case you may be able to achieve your intentions without removing the airbag.
https://www.f150forum.com/f118/adapt...2/#post5435397
Unless they changed something, the plastic trim pushes into grommets with pointed posts. You will not be able to adjust the seating depth with screws or anything like that.
Old Dec 13, 2024 | 08:14 AM
JoeUser's Avatar
JoeUser
Wow, that's a HUGE help, thanks! I never found that thread when searching earlier (or, overlooked it), but the picture showing how the trim piece with the controls attaches (via those tapered posts) is very helpful. I guess I should've known that for ease and speed of assembly going down the line in the factory it makes sense to just push and snap that trim into place. Many years ago that trim would've been held in place by small screws, I'm sure. Actually, that would be my preference, as it would've been a more solid attachment to hold the leather wrap in place.
OK, I'm no longer intimidated by that trim piece breaking, when I pry up the areas around the three spoke areas. I won't even have to remove the airbag. I reckon I'll have to see if it will snap back into place with the edge of the leather wedged beneath it, but I'll get it sussed somehow.
Thanks again for the link!
bigcountry1009
Appearance & Dress-Up
Apr 14, 2022 10:39 AM
Pickledboater
Feb 11, 2022 05:51 AM
frysl
Jan 22, 2022 01:32 PM
eyemgh
Jan 12, 2022 12:53 PM
longview1
6.7L Power Stroke Diesel
18
Jan 18, 2011 12:03 PM
