Trans P1783 - help
Old Dec 10, 2024 | 04:02 PM
casray's Avatar
casray
Trailering
Trans P1783 - help
2007 F150 4.6L 2WD
Hi guys-
I thought I had figured out my trans issues by replacing the trans cooler, the front-end cooling lines, and just recently the thermal bypass valve. I went on a 40 minute ride to get things warmed up to then check to see if the cooling system was working. But, the trans started making that whirring sound whenever I would give it even a little gas to accelerate. I then saw on the odometer the ‘service trans’ message. My BlueDriver gave this code: P1783 Transmission Overtemperature Condition. Here’s the crazy part: I crawled under the truck to check the cooling lines, they are all NOT HOT. Not even the output line from the trans. AND the dipstick shows plenty of fluid. Is there some kind of pump in the transmission that can go bad? It’s the only thing I can think of since the output line isn’t hot before it gets to the bypass valve.
Any thoughts? Thanks
Old Dec 10, 2024 | 07:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, there is a pump in the transmission. If it goes bad the trans won't go into any gear except park. The pump is not your problem.
Something inside the trans is blocking the flow to the cooler. I don't know this trans well enough to get really specific on what's wrong.
casray
2004 - 2008 F150
Nov 11, 2024 01:30 PM
Carnes99
Dec 21, 2019 06:56 AM
Grantford
Jul 4, 2019 10:03 AM
Liquid10Rider
Dec 4, 2017 12:37 PM
BrokenBit
13
Jun 4, 2008 08:28 AM
