Starter
Old Dec 9, 2024 | 09:20 PM
keenem68's Avatar
keenem68
7th Gear
Starter
Trying to remove starter out of 1950 f3 truck. Have removed all bolts that hold it in place but not able to swing down plate that it is atteched to . is there something else I should do. PS it will wiggle so it is loose. Thanks
Old Dec 9, 2024 | 10:06 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
You don't remove/loosen the plate.
You loosen the two starter length bolts at the end of the starter and pull the whole starter out. These bolts thread about 3/8" into the mounting flange. Don't pull these bolts out of the starter as the starter will come out in pieces that is not fun to reassemble.
Old Dec 10, 2024 | 08:33 AM
mtflat's Avatar
mtflat
There may also be one "L" shaped bracket under one of the mounting bolts that attaches to a bolt on the oil pan. Remove the oil pan bolt to free this bracket.
Sonic001
Dec 10, 2023 05:27 PM
twise
May 21, 2009 02:26 PM
mojoman
32
Dec 2, 2008 08:10 AM
etnies13
Jul 14, 2006 08:43 AM
Rough52
May 12, 2006 01:13 AM
