Antifeeeze circulation
Old Dec 6, 2024 | 05:09 PM
SpencerPJ's Avatar
SpencerPJ
I’ve lost a bit of antifreeze, maybe 1 qt. I don’t see any obvious spots, I feel it happened on a cool down with truck on a goofy angle in a cold climate.. I added a small bottle 1 oz of antifreeze glow dye to the overflow hoping if it leaks again I will find it . Will that mix throughout system that way? I’ve driven hundreds of interstate miles, the overflow has not changed levels, the dye sure glows with a purple light in the overflow, I just don't know if the system will or has cycled it throughout the radiator, hoses and systems? It's not like I can peek in the radiator. Your thoughts if it has circulated throughout?
Old Dec 7, 2024 | 11:32 AM
cps's Avatar
cps
i believe you should have added it directly to the rad. Faster results.
Old Dec 9, 2024 | 10:02 AM
GlueGuy's Avatar
GlueGuy
I think (but I don't know for sure) that a few times around the circulation system will mix it up pretty well. After all, you don't put water and antifreeze in "together"; you pour in one, then top off with the other and it seems to mix up just fine.
rogermarcon
Oct 15, 2020 07:00 PM
Schuyles
Feb 12, 2012 11:09 AM
joekacker
Aug 30, 2011 10:12 PM
tdwhiteIII
1978 - 1996 Big Bronco
Feb 6, 2006 08:51 AM
Ken2600
Oct 18, 2002 03:03 PM
