I have a new to me 2019 F350 6.7 diesel, this is my 3rd ford diesel. On this one when I remove the fuel cap it sucks in air, the other 2 didn’t do that. My 1st was a 2010 (6.4), 2nd was a 2017 (6.7). Ford says that level vacuum is normal (no codes) doesn’t seem it to me though, any thoughts?
Since diesel doesn't evaporate like gasoline does, it doesn't have an emissions system like on Gas tanks. It has a rollover valve on the top of the tank to equalize pressure. IIRC its on the top rear of the tank. It's suppose to allow air in to offset fuel used.
Does it have the original fuel cap on it?
Believe they are vented on a diesel, so maybe has the wrong cap.
This is on a Titan tank, but stock should be similar, This tank shows 2, one by the fill and overfill tubes, which is I think where stock is and another one near where the water separator goes.
