AMP Step Problems
Old Nov 29, 2024 | 05:07 PM
gcraver7's Avatar
gcraver7
6th Gear
AMP Step Problems
Hey I’ve got a 2015 F-250 with a pair of Amp steps. I love them and have been working great for the years they have been on the truck. A couple weeks ago they stopped working. I checked the fuse and it had popped, so I replaced it and got them to go down, but after that no worky. So I tried some simple troubleshooting with no results. I ordered a new module, and that didn’t fix it. After some tinkering, I got both the new and old module to work in reverse, but only if the main nine pine harness was plugged in. If I plugged in the small harness it wouldn’t work again. I have tried every way to plug and unplug the module, put in the fuse, and unhook the battery. I can’t get them to work normally. So today I swapped the polarity of the motors. They work, but with one problem, the timing is off. The normal shut door delay happens when I open it. So if I open the door it takes a second to deploy, and then if I close it they retract immediately. They again only work with the nine pin harness connected, so I have no lights either. I have tried contacting amp multiple times and cannot get a hold of them. Does anyone have any solutions? Thanks. If any clarification is needed please ask.
Old Dec 17, 2024 | 04:18 PM
Nbtomcat33's Avatar
Nbtomcat33
1st Gear
Did you get this figured out? I did the exact thing you did reversed the polarity in the passenger side motor and they both deploy and retract when either door is open. Lights do not work either.
Old Mar 3, 2025 | 06:43 PM
John in OkieLand's Avatar
John in OkieLand
Hey guys,
my Power Steps work like they should,
EXCEPT the Delay is reversed.
Open door, takes 2 seconds for them to go down.
Close door, they go up Instantly.....
I have emailed them for instructions, and nothing, no reply, just the automactic email that says " we will get back to you asap "
that was a week ago... they don't service their customers, period.
Old Apr 1, 2026 | 03:44 PM
dixiepc's Avatar
dixiepc
4th Gear
Has anybody found a solution to this?
Old Apr 1, 2026 | 08:54 PM
John in OkieLand
I called them on the phone.
told me to reverse the motor leads at the motor,
never got around to it.
slow down, super fast up.
need to reverse the motor leads
SMarquez
Mar 22, 2022 08:30 PM
MDK123
Apr 7, 2019 08:32 PM
Mkos1980
Jan 29, 2019 07:57 AM
Brian Rose
1997 - 2003 F150
28
Feb 7, 2018 12:18 PM
travpeg
6.7L Power Stroke Diesel
Mar 15, 2013 09:07 AM
