Has anybody attemped this using the amp boards brackets and motors and use the Ford module and make their own harness? Prices have skyrocketed on OEM parts to over 2000 not including the build of the harness or connectors. And this was online prices. If the amp boards can be had for 1300, ford module for 90, enable it, and build a harness could it be done? Id like to know how much difference the AMP motors are over the factory motors.
I don’t have an answer to your question, but I do have an extra set of OEM steps taken off with 4,000 miles on the clock I’d part with for AMP prices... sorry don’t have the harness or module
Ford Super Duty trucks have the muscle to get to work, and get the job done with confidence.
Did the Ford marketing team hijack your account or something? Why do you keep spamming these random marketing phrases to unrelated threads? This has nothing to do with AMP steps. This is the third instance in the past few days, and your posts before that are half unrelated broken English gibberish. What are you trying to accomplish? Please stop. Keep your posts on topic.
Are you using a translate service, because no one talks like that.
Do a search. Someone did do a nice install using factory components. He made a wiring harness and went through all the steps on the install and programming the truck.
