Miss
Old Nov 24, 2024 | 12:59 PM
NM76F150's Avatar
NM76F150
Miss
95 7.3 manual Banks Turbo.
10 minutes after fueling up I’m driving down the highway about 65mph and I experience what feels like a miss fire in a gas engine car. Just one. Now I’m super alert because I’m about to drive through some country with no cell service. 20 minutes later it happens again. Nothing odd on the tach and I can accelerate the truck with no issues. Then I drive 200 more miles no issues whatsoever.
Went start it the next day, no problems and again on a short drive no problems.
What do guys you think? Contaminated fuel (water) or a sign of more problems in the future.
Old Nov 24, 2024 | 01:07 PM
z31freakify's Avatar
z31freakify
Could be anything, only way to know is to check for codes.
Old Nov 24, 2024 | 03:23 PM
97-psd's Avatar
97-psd
Could be fuel. Do you have a spare CPS in dash? If not, I would probably get one
Old Nov 24, 2024 | 05:31 PM
NM76F150's Avatar
NM76F150
Yep. In the glove box.
I figured CPS would affect the tach.
Old Nov 24, 2024 | 07:10 PM
97-psd's Avatar
97-psd
If it is a quick miss you may not see/catch it. Mine did that several years ago and it ended up being the CPS. Yours may be fuel related but keep an open mind.
Old Nov 25, 2024 | 08:36 AM
NM76F150's Avatar
NM76F150
I’ll probably just replace the CPS. Easy and cheap enough.
Old Nov 25, 2024 | 09:15 AM
Yeoman's Avatar
Yeoman
Could it be air?
If there is a minor fuel line leak allowing air to reach the injectors you could get an intermittent skip.
When or did you ever change the high pressure fuel lines? Check for a corroded fuel line from the tanks could also be a source of air.
Old Nov 26, 2024 | 02:17 PM
97-psd's Avatar
97-psd
Normally, not always, but a corroded fuel line with cause it to run bad all the time, or not run at all.
hopefully the new CPS will fix your problem. Good luck and let us know if it resolves the problem. People in the future will thank you.
Old Nov 26, 2024 | 03:10 PM
Yeoman's Avatar
Yeoman
If you decide to the CMP (CPS) aka cam sensor unit, use genuine Ford parts. The aftermarket stuff is just bad.
Old Dec 6, 2024 | 12:05 PM
NM76F150's Avatar
NM76F150
Follow up.
Changed the CPS with the latest Motorcraft version. The one I took out was the old black one so it couldn’t hurt to update.
Since the original hiccup I’ve driven 600 miles (400 since CPS) with no issues. Including a 19f start with no plug in.
Im still thinking it was contaminated fuel…..
cjgray1974
6.7L Power Stroke Diesel
Jun 22, 2024 02:58 PM
MoreSteam
Sep 10, 2011 11:46 AM
Iantiler
1983 - 2012 Ranger & B-Series
38
Mar 6, 2011 05:36 PM
bla1879
S. California Chapter
20
Jun 3, 2009 11:07 AM
ctfordguy
6.4L Power Stroke Diesel
Jan 7, 2008 02:34 PM
