Paint inside valve cover
Old Nov 23, 2024 | 08:59 PM
vacuumbed's Avatar
vacuumbed
Our 6.0 engines seem to have paint inside the valve covers, it has a rubbery feel to it. Does anyone know what kind of paint that is?
Thanks in advance
Old Nov 23, 2024 | 10:49 PM
TooManyToys.'s Avatar
TooManyToys.
It's not paint.
The valve covers and the oil pan are made from laminated steel with a viscoelastic layer between, and sometimes coating. These products have been in use for a few decades. At my old brake friction material company, we used them as the noise-dampening shims on the back of the brake pads.
MSC, Material Science Corporation, made these. The head of their R&D used to work in the same department as I did.
Tap on the valve cover and the oil pan. They reduce the sound from the valvetrain and crankcase. In other motors, they're used to form the timing covers out of aluminum or stainless steel.
https://www.materialsciencescorp.com
Old Nov 23, 2024 | 10:55 PM
joe blow's Avatar
joe blow
Jack always has the answers
Old Nov 23, 2024 | 11:41 PM
TooManyToys.
Not according to my wife ... first, or second ...
Old Nov 24, 2024 | 09:50 AM
vacuumbed's Avatar
vacuumbed
Thank you Jack. Sounds like if that surface gets damaged, the valve cover has to be replaced.
Old Nov 24, 2024 | 10:31 AM
Fuzzpuss's Avatar
Fuzzpuss
We forgive both of them.
Old Nov 24, 2024 | 10:45 AM
TooManyToys.
Not necessarily. That coating is probably oil resistant and temperature resistant, so it may be OK with a gash.
22truckie
Nov 11, 2022 09:23 AM
WallaceSF
Jan 7, 2017 07:01 AM
Adam0331
Oct 10, 2009 10:07 AM
scoutpup99
3.8 & 4.2L V6
May 15, 2006 06:31 AM
'78 Custom
Paint & Bodywork
Jan 20, 2006 05:24 PM
