Happened to me the first time, initially nothing came out, but then the diesel started soaking through. Probably a small screwdriver and a gentle touch will clear it. Make sure you screw it closed properly or air will get in and get past the CP3 - I’d had my F350 for 24hrs when that happened and it took the rest of the day figuring it out and getting it to start…
Ahh... don't have a newer truck, have the DFCM, primary pump and filter, so I'll let the guys who have them answer. But that's weird alright... there's fuel in there and opening the drain should allow the fuel to come out...
If the drain petcock/**** is not loose (you can't wiggle it) then it's likely not disengaged enough to drain. If it comes down to it you can always put a bucket under the housing and loosen the bolts enough to allow fuel to drain out, then remove the base and see if there's any gunk clogging the drain hole.
It'll be a messy job, but hopefully it's just a case where the drain **** isn't fully disengaged. Remember, you have to push up and turn, so that you don't break the locking tabs on that **** when rotating it.
Thanks, I’ll give it another shot. If I just remove it from the housing, will the fuel in the line eventually stop flowing or is their a check valve type device that will prevent the continuous flow of the fuel?
It should stop flowing on its own, but some guys like to do this job with a 1/4 tank of fuel or less. Once you confirm the drain valve is completely open,...if it still doesn't drain, probe gently with a plastic rod like tool into the port where it drains out. It could be as simple as a spiders nest stopping the flow. (this happened to me). And like Joe said, push upwards slightly while turning counter clockwise, should be approx. a 1/4 turn to drain.
You could also make sure it is fully turned counter clockwise against the stop then pull down and remove it. I had to do this to remove mine for the 3rd party SPE aluminum replacement.
Great to get this response. I did purchase the aluminum one, I’m just a little skittish to try to do it myself. I’m not auto savvy. I tried finding a tutorial on how to do it without removing the housing but couldn’t find anything. It appears it takes a little force to remove and replace the part.
thank you. I have a 60 gallon tank and I didn’t want to lose a huge amount of fuel
I was a bit hesitant to do it initially even going as far as emailing SPE. They basically said it would come out with a little effort straight down once the plastic one was rotated fully counter clockwise and against the plastic stop. The last thing I wanted was a driveway full of diesel fuel if things went sideway.
It was pretty straight forward once I pulled straight down on the plastic one.
