huge parasitic draw. Help!
Old Dec 1, 2024 | 07:41 PM
mlanoux's Avatar
mlanoux
[QUOTE=hugho;21417831I see a whole passel of fuse links on the starter solenoid and need to find out what they serve but I will need a wiring diagram![/QUOTE]
By any chance, did you try removing those fusible links to see if one of them is the source of the draw? Agree you need a good manual but at least if you do this, and are successful at finding the culprit, when you do get the manual you'll know exactly what to troubleshoot.
Old Dec 2, 2024 | 10:30 AM
hugho's Avatar
hugho
4wd Low
Thank you gentlemen(women?) for your help. I have ordered factory manuals(NOT USB/CD) and a EVTM to get proper wiring diagrams. While waiting for delivery I decided to try to solve my other big problem: my NO START. I made the long trip back from Idaho to WY using the front tank as recommended by the PO. I had a full back tank and switched the tank the next morning. NO START. Switching back to front:Nada. With the helpful fuel pump wiring diagram posted here I found my tank switch was bad. Ordered a new one and pulled the old one out. I decided to check if pulling it out changed my draw. NO DRAW!. I left the battery connected and checked V in the morning and it was still 12.7 Volts. I checked the switch. the pins supplying the fuel level were fine but no continuity on the pump feed, mid or aft tank. Mystery appears solved.
Old Dec 2, 2024 | 12:24 PM
generalee's Avatar
generalee
Another way to track down the culprit is a harbor freight DC amp meter. They have several but they are AC so be certain before you buy to make sure it will measure DC Amps. I paid $85 for mine and was able to test several locations of circuits to watch when the computer shuts things off (wife's European trash car) and found the problem was the regulator not getting signal to charge. After testing my battery to make sure it was good I had to rule out parasitic drain and this was the ticket. My '84 Mustang had similar problem and it was the external regulator was not getting any voltage back from ammeter in dash/ignition switch. That's why a diagram is crucial.
Very helpful tool.
Very helpful tool.
Old Dec 3, 2024 | 02:59 PM
hugho's Avatar
hugho
4wd Low
thank you. I have a clamp meter but it seems to be great for big current flows and my draw was big: 3.49 amps. mine doesn't seem to like miliamp flows but then again it is not a Fluke. I think my draw is in a bad tank switch but I need to hook up my new switch to see if that fixes it. It could be in the pump wiring or even the pumps. stay posted
amsnss
Apr 24, 2014 05:11 PM
ididntdoit99
May 22, 2008 10:48 PM
Shane269
Aerostar
Apr 16, 2005 02:07 AM
cpnhgnjnky
Mar 9, 2005 03:28 PM
Zoomie331r
Jul 25, 2004 11:16 AM
