Proactive maintenance/ part buying ?
Old Nov 20, 2024 | 08:21 AM
Ironhorse2022's Avatar
Ironhorse2022
Hi everyone, my 97 F250 HD has 60k rust free miles and is running well. I’m pleasantly surprised by how many OEM parts are still available at reasonable pricing (I’m used to 1970’s and 80’s where that’s the not the case). I’m consider proactively buying a few parts that typically go bad on these trucks before they are rare and expensive. Potentially things like a dual tank switching valve and switch, window motors and rollers, etc. Can you give me feedback on the most common parts that fail early (pre 100k). Also any feedback in general you have on this concept is welcome.
Old Nov 20, 2024 | 09:37 AM
1Butcher's Avatar
1Butcher
Many parts just wear out. Fuel pumps, coolant pumps, starters, alternators, hoses, belts, etc.
Parts seem to wear out if the vehicle is used or not. I have a 95 F250 and the drivers side window motor failed. I do have a regulator and the gear drive that is in the motor. It's on my list of things do to. Other than almost nothing has failed. I do not consider wear items as failed parts. Oh yeah, I did have an ignition lock cylinder wear out.
If you do not have a set of keys, get some made.
Old Nov 20, 2024 | 10:06 AM
1Butcher's Avatar
1Butcher
Not a bad idea to get your EEC-IV repaired [capacitors leak] as well as the PSOM. My PSOM was rebuilt [maintenance] last summer. My EEC-IV has no capacitors.
Old Nov 21, 2024 | 10:48 AM
Ironhorse2022
Thanks ! Good input.
Old Nov 21, 2024 | 10:26 PM
samuel4wolfpack's Avatar
samuel4wolfpack
Do you have a manual or automatic transmission?
Old Nov 29, 2024 | 07:50 PM
Ironhorse2022
Auto trans
Old Dec 1, 2024 | 10:08 AM
Scndsin's Avatar
Scndsin
If you plan on keeping it, start shopping the junk yards
Dash surround, identical computer or alternate same year/engine/trans, black motorcraft ignition modules, distributor, injectors, IAC valve, sensors, door panels, steering column, interior screws
cruise control module, ABS module, wiper module, seat back lumbar bladder, dash pad & dye to match
Under hood/body bolts, captured nuts clips, fasteners, window motors/rebuild/test...
Have used OE parts that have been tested on hand.
Anything that makes it run rather than running out & buying new aftermarket that may be dead out-of-box & adds to frustration.
Just off the top of my head.
Old Dec 1, 2024 | 10:17 AM
OBS460's Avatar
OBS460
I bought my OBS with 64k miles on it and nothing failed before 100k miles.
Old Dec 1, 2024 | 05:23 PM
Ironhorse2022
Thanks to both of you. Very helpful.
fun314
Feb 22, 2015 06:44 PM
tractoman
May 31, 2009 04:40 AM
rich gill
Oct 14, 2008 05:52 PM
billybobzia
Jun 3, 2004 08:59 AM
Crazy_John69
Aug 16, 2001 10:34 PM
