Originally posted by rgarrett I like that idea, he even has smaller rims/tires...only problem is he may not want to trade my rims back (he has the standard ugly steel wheels)
Darn...then you would have to get some 10x15 rims with 32X11.50 Kumho Venture MT tires.
If you are looking for tires, try looking at www.summitracing.com as they usually have some pretty good deals. Pro-Comp is made by BF Goodrich and has the exact same tread design and "digger lugz" on their MT tires, and they usually run $10-15 cheaper per tire than the exact same BF Goodrich tires. I had 35" BF Goodrich MT's before my Pro-Comps, and they run just about the exact same. Good luck.
i pulled a 98 exploder out of a ditch with my stock B'co and its front end was sagin about 3" from where it should have been and the tires were bald. The guy i helped was blown away, and told me he was going to go buy a Bronco, that was all the proof i needed
Swapping tires sounds like a good way to test them, I wish there was a tire shop I could try that at. This sounds like a dumb question but are you sure the 4WD is working. My Bronco has no problem keeping up with anything I have put it up against.
Friday here in MD we got 6-10in. of snow. Drove the Bronco to work and it sucked big time. At lunch went to Sears and purchased bfg a/t's. What a difference. Not only in 4x4, but driving in general! The old reguls had a ton of tread but had the drifting issues mentioned on this board at highway speeds. With the new tires on dry road today it is like a different vehicle. As for the 4x4, took it up my 1/2 mile long ice and snow covered driveway in 2wd no problem. (then of course drove it through my fields in 4x4).
I guess I have never had crappy tires on my suvs before? Anyway these tires made a huge difference so i supposed Ill keep the bronco for a while.
