Sponsored by: Auxito
Shifty Trans Issues
Old Nov 14, 2024 | 08:30 AM
SuspiciousLee's Avatar
SuspiciousLee
3rd Gear
Shifty Trans Issues
Well... My '97 F150 is not shifting out of first gear. I've changed the TPS, manual lever position sensor, solenoids and fluid. I've also checked the 1 2 accumulator for a broken spring. I didn't find any damage to the springs, piston or the bore.
I believe that the 4r70w that was in it has been swapped before I rescued it. The tag on the trans is unreadable.
Any ideas?
Old Nov 14, 2024 | 10:17 AM
Hit Man X's Avatar
Hit Man X
What happens if you pop it into manual 2?
Should take off in second gear and stay in it.
Old Nov 14, 2024 | 04:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Without reading the codes you will have a very hard time fixing it.
WorkVan58
Aug 4, 2008 07:28 AM
BIGREDFX4
1997 - 2003 F150
Oct 17, 2006 04:23 PM
cjbronco
1978 - 1996 Big Bronco
Aug 1, 2005 09:52 PM
jethro
Sep 23, 2001 08:34 PM
