4R100 cooler pressure
Old Nov 11, 2024 | 08:45 PM
robert kelsey's Avatar
robert kelsey
What’s the normal operating PRESSURE in the COOLER ?
Old Nov 12, 2024 | 08:50 AM
1Butcher's Avatar
1Butcher
Mark K will chime in to set us straight, but my understanding is that the oil leaving the converter goes to the cooler, then drains in the back of the transmission. There is a check ball at the rear fitting. Not certain when that cracks open, but it is used to keep the cooler circuit full [ie no drain back w/engine off]. I suspect the amount of pressure will depend on the amount of coolers and how much those coolers will restrict flow.
Unless you got a serious restriction, the pressure should not be that high. If you got the oil bypass at the side of the transmission, there is a check ball there that prevents the circuit from getting too much pressure. I want to say it's 75psi, but again, Mark K will set us straight. If it is indeed 75psi, the cooler circuit should not go higher than 75psi.
Old Nov 12, 2024 | 10:03 AM
robert kelsey
Yes the bypass cracks at 70 so max should be just about that… But what is normal operating pressure is what I'm wondering..
Old Nov 12, 2024 | 10:08 AM
1Butcher's Avatar
1Butcher
The pressure is the result of the restriction.
Old Nov 12, 2024 | 10:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Normal pressure in the cooler is about 30-60 PSI.
robert kelsey
Nov 13, 2024 10:31 AM
blanes
Aug 11, 2014 11:16 AM
rscotth
15
Apr 9, 2011 07:21 PM
stormyone
Oct 11, 2006 08:44 PM
