Front diff oil
Old Nov 8, 2024 | 04:26 PM
gweedo295's Avatar
gweedo295
Front diff oil
Hello all. Wondering which oil to use in the front diff 77 f350 highboy. What diff is this. These are the diff numbers. Thanks.
Old Nov 8, 2024 | 05:17 PM
440 sixpack's Avatar
440 sixpack
80-90 or something in that range as long as it's hypoid oil.
Old Nov 8, 2024 | 07:10 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 80/90 gear oil. Once you replace that leaking gasket....with a Lube Locker one. https://www.wildhorses4x4.com/lubelo...MaAt3LEALw_wcB
Fill it until your pinky tip touches it thru the fill hole. What is the axle code # on the (dvrs side door end edge) warranty plate tag?
That tag on the front axle is the ratio info on your front axle. Looks like you have 4.09 ratio. I believe the Dana BOM number is on the tag" 610010 4R
https://www.ford-trucks.com/forums/1...axle-tags.html
https://differentials.com/technical-...dentification/
Wipe off that 44 just to the left of the tag, does it say 44 6F?
Old Nov 8, 2024 | 07:28 PM
gweedo295's Avatar
gweedo295
I have the gasket, that’s the plan to change everything out. I’ll check the tag in the morning. Thank you guys
Old Nov 8, 2024 | 08:06 PM
77&79F250's Avatar
77&79F250
Well having "a gasket" and having "a Lube Locker gasket" is like the difference in a Ford 1972 Courier and a 2024 F350 Super Duty Crew Cab Long bed...diesel. Lol
Yes get that axle # off that tag.
Old Nov 8, 2024 | 09:16 PM
gweedo295's Avatar
gweedo295
Actually the door tag won’t help, truck is an f100 sitting on a 3/4 ton highboy chassis. I haven’t heard about a lube locker gasket unless it’s the one that comes with the sealant on it already.
Old Nov 8, 2024 | 09:34 PM
77&79F250's Avatar
77&79F250
So you did not xfer the metal tag from the door of the chassis doner truck? Any way that is a different discussion...a Lube Locker gasket does not need any sealant. Thru its design it does not need any wet/liquid sealant applied before installation on the gasket, the cover or the differential.
Old Nov 8, 2024 | 09:45 PM
Rubiranch's Avatar
Rubiranch
I went with 75W-90 full synthetic in the front & rear diffs, transfer case and the 4-speed transmission.
If there's a limited slip in there you will need a friction modifier.
It did make the 4-speed shift smoother too.
Old Nov 10, 2024 | 04:04 PM
gweedo295's Avatar
gweedo295
Finished, looked like new inside. I’ll attach a couple pics.
another ? Going to t change transfer case fluid n leaking gaskets. Do you know the model (pic attached) n what fluid/oil should go in.
thnx
Old Nov 10, 2024 | 04:30 PM
77&79F250's Avatar
77&79F250
Looks like a (New Process) NP-203 and it takes 30wt oil, it needs thinner oil because it "splash" lubes the internals. So NO 80/90 gear lube. Look at the front of the xfer case for a ID tag to 100% ID it. 205 stamp.
And a for sure 203 stamp.
NP-205 on the left and NP-203 on right.
203 left, 205 right.
What oil talk: "The owner's manual recommendation is to use SAE 30 non-detergent motor oil. Is there something that would be better from the perspective of protecting gears than a motor oil?
For those not familiar with the NP 203: It is an all wheel drive transfer case for full size pickup trucks. The transfer case has a two speed gearbox at the front much like a non-synchro manual transmission rather than the planetary set found in most transfer cases. It has a differential behind the range box and a chain to the front output.
The lubrication for the range box is just like a manual transmission. The lay-shaft sits about 1/2 submerged and carried oil lubricates the main shaft bearings and gears. The differential is lubricated by oil carried by the chain using an oil catch. The rear output bearings are then lubricated by splash captured off the differential.
I've read warnings on the internet to not use gear oil because the rear output bearings don't get oil from the multiple relay of oil up from the sump. So it would seem that a lighter oil would be necessary. But I question the long term life when lubricated with a motor oil vs. an oil package designed for gears, roller bearings and ball bearings."
https://bobistheoilguy.com/forums/th...%20motor%20oil.
What weight oil for 203 transfer case https://www.ford-trucks.com › forums › 1556755-what-...
Sep 27, 2018 — The NP203 uses 10w-40 motor oil. People severely hurt their 203s by using either gear oil (90w) or transmission fluid (18w) in their cases.
NP203 Oil - Ford Truck Enthusiasts Forums
Apr 18, 2017
Oil Change NP 203 (1977) - Ford Truck Enthusiasts Forums
Oct 27, 2019
Oil advice for NP 203 transfer case - Ford Truck Enthusiasts
Jan 16, 2003
NP203 oil and capacity? - Ford Truck Enthusiasts Forums
Dec 3, 2005
www.ford-trucks.com&sca_esv=2c272caab9e83ec0&sa=X&ved=2ahUK Ewj5rdm-59KJAxXtm4kEHWs8NzYQrQIoBHoECDMQBQ]More results from www.ford-trucks.com
Old Nov 18, 2024 | 01:09 PM
gweedo295's Avatar
gweedo295
What are these
I serviced the front diff. Couple day days later I noticed oil leak. I cleaned it off good n let it set. It’s not coming from the gasket but it is from these two spots. Can u tell me what these are n how would I stop the leakage.
Back side of front diff
Old Nov 18, 2024 | 03:24 PM
nutter3's Avatar
nutter3
Those are plug welds the factory uses to hold the axle tubes in the differential housing. I believe the tubes are a press fit into the housing, then they additionally plug weld these spots. I think you can clean up this area really really well and reweld them, but be aware of fire potential with oil in the area.
Old Nov 18, 2024 | 05:49 PM
77&79F250's Avatar
77&79F250
X2 what he said.
Old Nov 18, 2024 | 06:28 PM
gweedo295's Avatar
gweedo295
Thnx, I’m wondering if jb weld would work. I can weld but not sure how thick the plug is. Hate to burn it n open a can of worms.
Old Nov 18, 2024 | 06:37 PM
NCHighBoy's Avatar
NCHighBoy
You won't burn through. The tubes should be 3/16" maybe even 1/4", keep the heat within reason and you'll be fine.
I'd be interested to know why they are leaking though... is your housing bent?
