Coming across conflicting information on NP203 oil viscosity recommendation Haynes book is saying 140w gear oil, other web sources are saying don't you dare use heavy gear oil, but use 10-40w motor oil.... The stuff it leaks looks to me like a 10-30ish motor oil...... And I know there are numerous different setups for the 203, mine being divorced with axles and grease zirks as far as the eye can see .... Any input is appreciated, I will keep poking around the web ........
That xfer case set up it a "sling lubed" and you need a thinner oil. So yes motor like 10W30 and NO 80/89 gear lube like a normal NP-205 or Dana 60 uses.
Also at least one a month lock it in 4wd and drive it on NON hard backed surfaces for a bit. Dirt, gravel, sand, mud, what ever is fun.
