Sponsored by: Real Truck
2X4 INFO
Old Jan 9, 2003 | 09:18 PM
Fishin Technician's Avatar
Fishin Technician
2X4 INFO
I bought 600 lbs of that tube sand (the imported kind) 60 lbs per bag........put them across the bed ON TOP of the axle........hopped real bad , just moved 4 bags just to the rear of the axle big change in traction........after this winter.........new truck on the way 4wd.
dan ft
Old Jan 9, 2003 | 09:26 PM
nafzimo's Avatar
nafzimo
2X4 INFO
>dan ft
I put eight 70 lb bags over my axle with no problems. What do you mean by hopped real bad?
Matt
2002, F250 SD, SC, 8' Bed, V10, 3.73 LS, Arizona Beige, ICI Stainless Step Bars, Truxedo Tonneau, Prodigy Brake Control, Flowmaster 40
Old Jan 10, 2003 | 10:53 AM
jade97's Avatar
jade97
2X4 INFO
I have (6) 40lb bags of topsoil over mine without any problems.
Old Jan 10, 2003 | 08:27 PM
Fishin Technician
2X4 INFO
.sorry, let me clarify..........i got 2 wheel drive........xxx heavy rear springs........it takes 600 lbs just to make them move some.i am not kidding.........i have LS 3:73 REAR also HD front suspension..........it takes alot to make these springs work............i got a e150 van//////great in the snow.....loaded..........got a older f250 ///300 //6 //great in the snow..........this beast .....NEEDS TO BE MAXED IN THE BED to move
d / ft
Old Jan 10, 2003 | 09:18 PM
wolfmanagh's Avatar
wolfmanagh
2X4 INFO
You only used 600 lbs? I have to use 1000+ lbs in my bus. 500 is to counter the weight of the engine, than another 500+ for the traction weight. With no weight I know I can get the rear end off the ground.
Old Jan 10, 2003 | 11:24 PM
nafzimo's Avatar
nafzimo
2X4 INFO
>d / ft
I have 560 lbs and you can't tell the truck has anything in it either, but what about the hop? Wheel hop? In the snow?
Matt
Old Jan 11, 2003 | 08:17 AM
Fishin Technician
2X4 INFO
yes i mean wheel hop in the snow. even when i gently touch the gas. probally is the stock firestones....maybe i need a different tire for more bite.
Old Jan 12, 2003 | 04:08 PM
Dave S's Avatar
Dave S
2X4 INFO
Wow... My '01 F-250 SuperCrew 4x2 pulled 3 vehicles (Proudly, none were Fords!) out of ditches this last snow here in St. Louis. I used ten 50# bags of play sand at the tailgate. No spinning, no hopping, just traction. I'm also off those crappy stock tires, though... Using Michelin ATX M/S tires... Those babies are AWESOME!
Dave
Dave's Guns
Home of the $5 Transfer
Serving the St. Louis Metro East
Old Jan 12, 2003 | 04:36 PM
rattler's Avatar
rattler
2X4 INFO
I put about 500 lbs.of cinder blocks over the axel after getting stuck in 3 inchs of snow on a practically level area. Made a big difference. I have a 02 4x2 F250SC with LS. Stock tires will go when a good deal comes along.
Old Jan 12, 2003 | 09:29 PM
reeltime's Avatar
reeltime
2X4 INFO
429unibody
Sep 28, 2010 09:01 AM
nathansharkey
6.7L Power Stroke Diesel
27
Aug 5, 2010 02:50 PM
clearnetedm
Sep 14, 2009 06:19 AM
F-250 Super Duty
General Diesel Discussion
20
Mar 2, 2009 10:35 PM
ctfordguy
2004 - 2008 F150
37
Jan 11, 2006 07:13 PM
