Barometric pressure sensor, vacuum line?
Old Nov 5, 2024 | 11:32 AM
WCMtn1990's Avatar
WCMtn1990
Should the barometric sensor have a vacuum line connected to it? Mine does not have a vac line connected and I am getting a code 22 for MAP or baro sensor out of range--the electrical connection looks clean and no obviously damaged wires.
Edit: Ok so some more searching seems to indicate that there should be a vac line to the sensor but I can't find anything under the hood to attach here. Is this a line with a special connector or just regular vac line?
Edit 2:More reading and then thinking it through leads me to no vac line being connected to the sensor which of course makes sense as far as it's operation as a barometric pressure sensor as opposed to a MAP sensor.
Old Nov 5, 2024 | 03:02 PM
Olds64's Avatar
Olds64
The moderator @tjc transport can move your thread to the appropriate forum. The ol' IDI diesels don't use a barometric pressure sensor...
Old Nov 5, 2024 | 03:08 PM
tjc transport's Avatar
tjc transport
i ain't rite
actually they do, but only if you have a E40D trans.
Old Nov 5, 2024 | 04:58 PM
Olds64's Avatar
Olds64
I thought that was the case after posting. Oh well.
Old Nov 5, 2024 | 06:29 PM
WCMtn1990's Avatar
WCMtn1990
I was excited for a moment when I saw there were responses. Oh these blankety-blankin' sensors.
renoyote
Feb 2, 2023 01:41 PM
johnarahill
Nov 26, 2011 09:35 PM
CHEVY-EATER
Feb 23, 2009 06:34 PM
scott9050
Aerostar
Jul 8, 2002 06:08 PM
