6.9 idi cutting off after revving...ideas?
Old Nov 4, 2024 | 07:45 AM
1986Dually's Avatar
1986Dually
1986 f350 with 6.9 idi....been sitting for a year or two....hardly any driving. It starts and idles great. But if you give it power, especially rev it up and come off the throttle, it cuts off. Where do I start first? I was given the truck so just getting familiar with it. Thank you for any tips.
Old Nov 4, 2024 | 10:59 AM
tecgod13's Avatar
tecgod13
Just to clarify, do you mean you stomp the pedal, then TAKE your foot off, and instead of returning it idle, it dies? Or you do mean you stomp the pedal, KEEP your foot there, it revs up, then dies with your foot still on the pedal?
If its the first, and it does when trying to return to idle, that is an easy fix, governor in the injection pump is sticking. Drain the fuel filter, fill it up with ATF, start truck and let it idle for 30 seconds, then shut off and let it sit overnight. In the morning, start it up and drive it hard. Repeat if symptoms persist. The ATF sitting in the pump will clean up the gunk that is causing it to stick.
If it was dieing with your foot still on the pedal, do either of the fuel filter warning lights come on? You could have a blocked fuel filter, dying lift pump, or blockage somewhere in the fuel line leading to the engine.
Old Nov 4, 2024 | 11:31 AM
1986Dually's Avatar
1986Dually
Thanks tecgod! It's the first scenario. Do you mean drain the fuel filter and fill the fuel filter up with automatic transmission fluid? Could I just replace fuel filter too?
Old Nov 4, 2024 | 03:04 PM
Olds64's Avatar
Olds64
You could replace the fuel filter while you're at it. The key is to fill the new one with ATF and run it a short while before letting the truck sit overnight. I use Wix 33811.
Old Nov 5, 2024 | 08:03 AM
tecgod13's Avatar
tecgod13
If you haven't replaced the fuel filter in a while, definitely can replace it. They will however last a long time. My last one was on for over 3 years (forget the miles) and still going strong, got clogged because I accidentally put in some crappy fuel with some sludge in it.
The filters (at least for a 7.3) are rather expensive, upwards of $30, and more locally. My truck has the fuel heater removed and a plug screwed in from the top, makes it real easy. I just use the water drain at the bottom to drain out the whole thing into a can, then top it up from the top through the heater hole. That may not work for your setup.
Old Nov 5, 2024 | 07:40 PM
1986Dually's Avatar
1986Dually
Thank you all! Great tips..I will try this weekend
Planet automobile
Nov 9, 2022 09:14 AM
idiambulance
Jun 6, 2021 06:38 AM
Scratcher
Ford Truck Parts for Sale
Sep 24, 2012 06:16 PM
Fireman_dave
Oct 6, 2011 12:02 PM
thedieselkid
39
Dec 23, 2009 05:59 PM
