460 PIP code
Old Nov 4, 2024 | 06:16 PM
rla2005's Avatar
rla2005
Originally Posted by obsxl
The oscilloscope would only show a problem when the PIP is messing up, not while it’s working, wouldn’t it?
Many times a failing PIP will display a weak/abnormal wave form.
Old Nov 9, 2024 | 01:19 PM
obsxl's Avatar
obsxl
So I finally got an oscilloscope and was able to read the PIP sensor output, signal seems pretty good.
Old Nov 10, 2024 | 04:51 AM
manicmechanic007's Avatar
manicmechanic007
Those black stators were all recalled? and replaced with white ones
If it is black, it will be coming apart and failing
The DU30C Motorcraft stator you need has white plastic
That wave does not look nice and square to me
Old Nov 10, 2024 | 08:42 AM
rla2005's Avatar
rla2005
I would agree with the above. Those PIP pulses do not look "square" to me either.
Old Nov 10, 2024 | 10:51 AM
obsxl's Avatar
obsxl
Are you referring to the drop on the edge of the wave or the narrow wave? I wasn’t aware there were 2 different color stators.
Old Nov 10, 2024 | 10:57 AM
95 obs's Avatar
95 obs
5th Gear
saw plenty of those fail when hot, worked for ford years ago. some never were replaced correctly either, make sure distributor shaft bearings arent loose.
Old Nov 10, 2024 | 12:12 PM
obsxl's Avatar
obsxl
I found this picture from another thread that shows what a PIP signal looks like, to me it looks pretty similar to mine. Some other pictures I’ve seen look about the same. I’d like to test the PIP when the truck won’t run.
Old Nov 10, 2024 | 03:55 PM
rla2005's Avatar
rla2005
Good catch finding that photo of the PIP pulse train. I would expect a cleaner square wave. Definitely good to monitor that while trying to catch when the engine stalls.
Old Nov 10, 2024 | 05:29 PM
obsxl's Avatar
obsxl
the shaft seems pretty tight, but if I have to replace the sensor I’ll probably just replace the whole distributor
Old Nov 10, 2024 | 05:30 PM
obsxl's Avatar
obsxl
I’m gonna keep the oscilloscope in the truck so I can check the PIP signal if/when it messes up again.
1990f250engine
Nov 10, 2024 05:32 AM
hwheeler
Jul 30, 2023 11:35 AM
izmepeggy
Apr 13, 2016 04:56 PM
tlawssss
Jun 23, 2012 07:34 PM
roughcreekgang
Apr 11, 2003 10:09 PM
