Truck misfiring PLEASE help
Old 04-12-2016, 05:59 PM
izmepeggy
izmepeggy is offline
izmepeggy is starting off with a positive reputation.
1988 F-250 460 ci. It stopped running while driving. Misfires when started. Last Jan. it stopped and a new distributor was put in and a tune up. Was running great. Then in March it did the same thing.Could I have gotten a bad one? It was new and not rebuilt one. It is throwing code 14.
Old 04-12-2016, 06:25 PM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Code 14 is CM only. Did you clear the codes after replacing the distributor?
Old 04-12-2016, 06:31 PM
izmepeggy
Yes,I have disconnected the battery a number of times. And what is CM. I've never had it throw that code before.
Old 04-12-2016, 06:35 PM
rla2005's Avatar
rla2005
CM = Continuous Memory aka Stored Code. You most likely have a bad PIP sensor in that new distributor.
Old 04-12-2016, 06:44 PM
izmepeggy
You would think you'd get a new part that would last longer than 2 months.
Old 04-12-2016, 06:52 PM
rla2005's Avatar
rla2005
I agree. That PIP code is a sure sign of a bad one. But it is only from CM so it may take a few dtive cycles to appear. If the battery cable has bern removed in recent past, it's a valid recent code.
Old 04-13-2016, 03:44 PM
izmepeggy
I'm having trouble finding someone to put the distributor in. I may just have to try to do it myself. I've never put one in before but it may be the only choice I have.
Old 04-13-2016, 04:56 PM
rla2005's Avatar
rla2005
It's not too tough. Look on the web for how to do it.
MOSPARKY
11-24-2017 04:32 PM
Jdk2008
2004 - 2008 F150
06-05-2017 08:30 AM
egoulet
Ranger & B-Series
08-25-2016 03:47 PM
NMSOLRBACON
1999 to 2016 Super Duty
03-10-2016 09:24 PM
Mvenem
3.0L V6
01-18-2016 04:59 PM
Quick Reply: Truck misfiring PLEASE help
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
