460 PIP code
Old Nov 3, 2024 | 05:41 PM
obsxl's Avatar
obsxl
460 PIP code
So I got in my truck (1994 F250 460) the other day and it wouldn’t start, it would crank but didn’t fire. Didn’t have time to mess with it then, but the next day I went out and it started up like normal. Couple days later I was driving it and it died while going down the road like someone shut the truck off. It restarted then too. So today I read the codes and got KOEO code 211 which is a code for the PIP sensor in the distributor. Looking at other forum posts it’s most likely the PIP sensor going bad or possibly the ICM? Could a bad connector or dirty PIP sensor also cause this? Any thoughts?
Old Nov 4, 2024 | 05:08 AM
95 obs's Avatar
95 obs
5th Gear
Thumbs up profile ignition pickup
normal condition on older fords, those things blow like light bulbs! . pull out distributor, will need a press to push out the camdrive gear, change pip. reassemble all & make sure its together right... some models had this externally bolted to lh inner fender well. (even eisier to replace)
Old Nov 4, 2024 | 06:37 AM
rla2005's Avatar
rla2005
No PIP/Stator has ever been externally mounted on these trucks. It is located inside the distributor on all models.
Ignition Control Modules (ICM) are a different story. 1991 and earlier, the ICM is mounted on the distributor. You will find some of the 1989(ish) and up trucks with the 7.5L engine have remote mounted ICMs. 1992 and up trucks all gas engine engine trucks got the remote mount ICM.
Old Nov 4, 2024 | 07:04 AM
manicmechanic007's Avatar
manicmechanic007
Your ignition module should be black
If it's black and you have a code 212, you have some diagnosis to do
There are pinpoint tests for code 212 in the PCED
The Stator is the pickup
I'd replace them both with new Motorcraft parts
Then inspect the capacitors in your processor
Old Nov 4, 2024 | 09:13 AM
Scndsin's Avatar
Scndsin
I looked for a Motorcraft PIP earlier this year.
Let me know what you find.
Old Nov 4, 2024 | 10:35 AM
obsxl's Avatar
obsxl
I don’t have the PCED, is there anywhere else to find the tests? If the problem is most likely in the PIP or ICM I may just replace them both anyway.
Old Nov 4, 2024 | 11:30 AM
rla2005's Avatar
rla2005
Does the OP actually have a Code 212? The opening problem statement only listed Code 211.
Old Nov 4, 2024 | 01:38 PM
obsxl's Avatar
obsxl
it only showed code 211
Old Nov 4, 2024 | 01:54 PM
rla2005's Avatar
rla2005
I see no need to replace the ICM at this point. Even the Motorcraft branded ICMs are proving to be troublesome. Plenty of counterfeit versions out there. If you feel compelled to have one handy, the black remote mount ICMs rarely fail, I would try to find an original Motorcraft version at a local Pick-n-Pull.
Old Nov 4, 2024 | 02:15 PM
obsxl's Avatar
obsxl
More likely it’s the PIP sensor then. Is it worth trying anything other than replacing the sensor or distributor? The problem is very random/intermittent right now.
Old Nov 4, 2024 | 02:39 PM
rla2005's Avatar
rla2005
A few folks have purchased relatively inexpensive oscilloscopes to view the PIP wave form. You could and should check/clean the connection (both ends) between the distributor and ICM before replacing any parts. Also inspect the inside of the distributor to see if there is debris in the bottom that could be triggering the erratic PIP code.
Old Nov 4, 2024 | 03:55 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I believe it was Scndsin that has a picture of the inside of his distributor showing the PIP covered in debris.
Old Nov 4, 2024 | 04:36 PM
obsxl's Avatar
obsxl
The oscilloscope would only show a problem when the PIP is messing up, not while it’s working, wouldn’t it?
Old Nov 4, 2024 | 04:37 PM
obsxl's Avatar
obsxl
can it be cleaned with the distributor in the engine?
Old Nov 4, 2024 | 04:50 PM
Scndsin's Avatar
Scndsin
Remove the rotor, 2 screws holding shutter wheel.
Brush, compressed air, vacuum cleaner or electrical cleaner.
Anything to get the crap off the magnet
