Engine help
Old Oct 31, 2024 | 06:24 PM
Thestudent's Avatar
Thestudent
7th Gear
Engine help
I'm trying to figure out what the engine year, correct size, or what it might have came out of. It has a 77 F100 carb spacer, a mercruiser intake casting #D30E-8425-AA and 302 heads. Can't get a proper number from the block. Just curious if there is a way to find out what it is? Y-block?
Old Oct 31, 2024 | 07:05 PM
85e150's Avatar
85e150
If it has 302 heads it's probably a 302. Or one of the other related engines.
221 or 260: not likely.
289: not unless it's really old
302: most likely as that manifold number is for a 302 and comes up under Mercruiser.
A 302 manifold will fit the 221, 260 and 289 but that's less likely
351w: can't be, manifold wont fit.
Y-block: can't be, different design, different engine family.
Can't tell year or original application without block casting number and date code. And then it's a guess as 302s were in most Fords in those days.
Old Nov 7, 2024 | 06:02 PM
5starCabF-3's Avatar
5starCabF-3
The Ford Mercruiser 302 engines used 351 w heads and the intake manifold has a J in it.
Josephgiardinasr
Jan 14, 2024 04:37 PM
srsbjohnson
Aug 6, 2013 04:28 PM
jaye
May 22, 2009 10:16 AM
Coastie97
General Automotive Discussion
Jun 10, 2005 04:50 PM
bornagain
Sep 29, 2004 01:15 PM
