Code 14, Ignition profile pickup?
Old Oct 29, 2024 | 06:27 PM
Tommy_Toohigh's Avatar
Tommy_Toohigh
Didn't start a couple times, now no start, turns over ok.
Recently replaced Ignition control module, could that have failed?
Code 14.
(Sings 'The Old Truck Blues')
Old Oct 29, 2024 | 07:03 PM
Franklin2's Avatar
Franklin2
Code 14 comes from the pickup inside the distributor. Could be the pickup, could be a connection or wire to the pickup. You can buy a pickup and replace it, but you have to take the distributor apart. You could buy a replacement distirbutor, buy I WOULD NOT buy a rebuilt distributor from the parts stores. They are usually remans from cardone and I have had lots of trouble with those. If you could find a NEW distributor, that would be best, but I do not know if they make such a thing to fit your engine. 2nd best would be to repair your distributor.
Old Oct 30, 2024 | 09:51 AM
Tommy_Toohigh
2 new available locally - steel or cast iron gear?
Verified cast iron
$20 more for (apparently) identical unit with a cast iron gear- OEM? The original is long gone
Old Oct 30, 2024 | 05:18 PM
Franklin2's Avatar
Franklin2
I think only some of the mustang engines had the bronze gear.
Old Oct 31, 2024 | 10:51 AM
Tommy_Toohigh
Gear
There appeared to be a choice between steel and cast.
For the record, NAPA had a 20% SPOOKY online discount for a new distributor, so I went for the in stock part. It popped right in, and I nailed the placement, timing was right on.
THANKS again for everything you do in this forum, MUCH appreciated!!!
Old Oct 31, 2024 | 12:40 PM
Max Capacity's Avatar
Max Capacity
Glad to hear, your back on the road. That was easy.
terry 1960
Dec 7, 2014 04:02 PM
tranzam81
Feb 28, 2009 12:14 PM
b4hntn
1978 - 1996 Big Bronco
Jul 1, 2008 05:09 AM
